Escorts 2nd SAS
I really need to get working on this. Summer will be over before I know it.
Same with my engine swap but thats so far on shedule.
I think I may find a set of coil buckets and do what you have done to yours and then replace what I have so that the truck won't be down for to long.
Sent from my SGH-T499 using Tapatalk 2
Been a busy day. Started out helping my buddy with the framing of his new shop. Got a little burnt, but oh well. After most of the day there, I went to my parents and used my dads drill press to drill the holes in the steering box for the hydro assist. Then on the way home I stopped and got a seal kit for it. Got the new seals in and ready to put back together. I thought my dad had a 1/4" NPT tap but guess not so I will have to get one tomorrow after work.
Sent from my PC36100 using Tapatalk 2
Awesome! What are you going to do for pump?
I have a saginaw from a Durango. Not to sure if I can make it work so I might look for a different one. But for now I will just keep using the stock ranger one.
That's just awesome. My truck is famous.
The bump stops are done.
Before...
After...
Finished...
Looks like it should work good, but the spring might rub on the passenger side when the axle drops.
first thing that came to mind......"red rocket" :D
