The two U-Pull its, one north of the Quest center and the other down on 60th. Don't bother for a little while, I was watching for you when I was there this morning... all they had was automatic V8's. I have seen manual V6's there before though. You can put the top cover and shifter assembly off the 97+ transmissions onto the older trans and get the same result but with easier to find parts.
If you are needing a shorter FEAD there was a 94 or 95 GT in the one north of the Quest center, I am fairly sure it would would work with yours. When I was shopping for a shorter setup I was told that it would work with my stock harmonic balancer, and since I think the water pump is the same length as yours it would work with yours too. Might check into it a little, the getcha is I think yours may be the different balance engine so if you gotta swap the balancer (and if yours is not a 50oz balance engine) your are out of luck. You would need the timing cover, water pump and obviously the brackets and accessories if it would work.
I don't know what color the interior is to your other BII but there was a EB BII that took a HARD roll in the same yard with really neat floor mats. They said Ford Bronco II and had the bucking horse, they were tan though.
I don't blame you any on those valve covers, they are pretty cool.
