4.0 ta 2.9 in a 95 ranger
the fun beguins, good luck dave!
off to the dump:bawling:
the donor
need to change the Y pipe, VC gaskets, and put the 4.0 flywheel on
then take the y pipe out of the 95 and slide the 2.9 in:yahoo:
drivers mount,right on
pass side,had ta get my die grinder out
in:yahoo:
Have you thought about using the 4.0 electronics on the 2.9l? Might have to fab a crank sensor mount, but it might solve the wiring issue...
SVT
SVT
There is no tone ring to run the crank sensor.
Personally, I think he best bet to so research the wiring others have done for wiring the 4.0 into a 2.9 dash and reverse the process.
Iirc, ain't the tone ring on the the crank pulley/balancer? They could be swapped, couldn't they? :dunno:
SVT
well, the easy part is done
used a 86/87 Y pipe. also have the converter
SVT
The tone ring for the 4.0 is part of the balance. I honestly do not know if it will swap onto a 2.9.
Well I hope you finish it, I'd love to see it running.
Event Coverage
TRS Merch
