Swick's Prerunner
Test fit those ruffstuff perches before you weld them. My deaver center pins were too big for the holes they laser cut. Its a pain to get the axle under the truck to realize you've gotta drill the holes out.
Thank you for the heads up. I did see your post on Dr about the issue. While I do the swap I will give the spring pack a prep.
sadly i have not made any progress with the axle. today i did go to the half off weekend at the local pick and pull. for 10 bucks i walked out with a switch panel with circuit breakers, cb antenna with two bases and a cable.
Swick's Prerunner
thank you. time and funds just have to fall in to place at the same time.
swapped out the ranger axle for the f-150 8.8 today. the swap went really smooth.
Swick's Prerunner
mock up.
Swick's Prerunner
Swick's Prerunner
installed
Swick's Prerunner
Swick's Prerunner
Swick's Prerunner
Swick's Prerunner
looks really good!
Looks like they fit together like they were from the factory. I like it.
Richard
looks really good!
thank you
Richard
went together like it was.
the axle came out of a 93 f-150 with a 5.0 motor with 4x4. the gear set that is in the axle is 3.55 l/s. the track width of this axle/wheel combo is 74" out side of tread to out side of tread.
Swick's Prerunner
^^thank you
this was today's effort. find the difference in the pics. only look at the truck. hint i did not wash it.
Swick's Prerunner
Swick's Prerunner
You cut the end of the bed up at an angle? You parked farther forward?
