Project Double R...
Finally had some time to start on the truck this afternoon.
Project Double R...
Project Double R...
Project Double R...
Leaf brackets plasma cut off.
Project Double R...
Project Double R...
Removed the overload from the Chevy leafs.
Project Double R...
This is the new wheel base.
Project Double R...
Project Double R...
One leaf set.
Project Double R...
Project Double R...
Bronco II tank fits like a glove.
Project Double R...
Project Double R...
Rained most of the day but I got a little more done today...
Project Double R...
Project Double R...
Project Double R...
Project Double R...
Project Double R...
Project Double R...
Looking good man. Id add a lil plate to your rear shackle hangers since you have them hanging off the frame. You'd be amazed on how much force is on those things
i may have missed this....is that an explorer 8.8 in the back?
you're mountaineer build has inspired me to do a D30 swap on my b2....picking one up this weekend
Thanks boss!:icon_cheers: Yeah I haven't decided how I wanna brace those rear shackle mounts I was thinking I might land the exo cage on the hanger some how so I am holding off on that until I start the flatbed. I need to order the DOM for the cage might do that tomorrow.
Oh yeah that is an Exploder 8.8 with discs in the rear. I plan on leaving the lower perches they work good as a U bolt skids. Going to build some anti-wrap perches to the top. Normally I add some lift to the perches by making them taller but not sure if I want to this time. Cause the front has a 3 inch lift on it now and the rear is already 5" taller as it sits. Hoping the weight of all the other parts will make the rear settle down some. Plus parking the truck on level ground should help too I hope. I think I will winch it off the flatbed today and see how she sits. Plus working on the flatbed is real PITA! :D
And yes the D30 is a solid contender as long as you beef it up some and stay at 37" or under tires. Make sure to snag Cherokee one 94-99 cause they are high pinion and have the larger joints in the shafts. You can get D44 760x joints and they are a direct fit in the larger shafts. Older axle are ok but I would steer clear of the CAD (center axle disconnect). The cast part of the CAD weakens the tube plus the 2 piece shaft sucks. If you find an older high pinion with the smaller shafts you can take shafts and unit bearings from a 94-98 Grand Cherokee they are same length and use the same unit bearing(I would just swap the shafts there at the junk yard so you don't have to pay extra for the shafts). But all Grands came with larger axle shafts. As long as the Grand didn't have CV shafts. Cherokee 00-01 had low pinion Wrangler axles steer clear of those. Happy hunting!:icon_thumby:
Going to order the lockers here soon the front will be high pinion 30 just like the Merc.
yeah i did alot of research before i started looking for one. i just couldnt find an XJ D30 anywhere around here. i knew to avoid the CAD D30's though. the one i'm getting is a TJ D30 with 373's. i have 373's in my 8.8 out back, so i wanted something to match without having to regear (the XJ 30's i did find had 3.07's or 3.55's or something else). i've never done a SAS before, so i'm using it as my guinea pig, i can upgrade later if i want. i'm only running 33's at the most and it will only see forest service roads and mild trails. thanks for the info, end thread jack
Got it off the trailer and fit the gas tank where it will be here are few pics. Hoping to have more time to work on it this weekend.
Project Double R...
Project Double R...
Project Double R...
Project Double R...
Project Double R...
Project Double R...
Got the design for the beadlocks today too!
Project Double R...
Had a friend and my son help me work on the roll on paint job today. Two coats down 4 more to go.
Project Double R...
Project Double R...
Also got some Rancho 7000MT 14" long travel shocks. Trying to decide if I wanna use them on the Merc or Rock Ranger.
Project Double R...
Actually it is Safety Orange from Team Rustoleum. :icon_thumby:
