I know I'm going to need another front end alignment. I looked for the answer so I wouldn't make a jerk out of myself and just post. My question is; am I going to need to do anything else to my suspension? I figured lift coils would be the best route. Don't like the coil washer spacer idea. Don't want my steering all warped like some guys stuff gets; and I'm sure its pretty illegal here in va anyway. Idk why people don't use tube steel as a spacer. My dad and his buddies used to use tube steel. And I'm somewhat baffled as to why there are so many urathane haters. Its good stuff. Doesn't wear like factory rubber bushings and body mounts. The poly spacers are however, damned expensive. About the same as coils which doesn't make sense to me. After I put the coils and maybe a half inch aluminum spacer in I'm going to get the chevy lowering shackles and re arch my leaf springs. Theyr almost level even with the over loaders on lol. Hopefully she'll look pretty good when I'm done.
If I could do it myself I damn sure would.
