Ranger axle swap
1986danger-ranger
I want to swap my rear drive axle. i have an F6 axle code and the gear ratio is 3.73. i want to put an 82 in it with a 3.08 reduction. What do i need to do to make this work?
always gotta be a dick. :icon_rofl: JK.
your gonna need to find that axle. hit up junk yards. or just have your axle re geared.
No, I was dead serious.
If we are talking about the 86 in his profile, it has a 7.5 (unless it was already swapped to an 8.8 and he hasn't told us).
I'm pretty sure 3.45 was the highest gears offered in the 7.5, meaning going to an 8.8 will be his best bet for getting 3.08 gears.
The fact that setting up gears is a PITA while doing a drop and swap on a rear axle isn't that hard also supports my response to the question.
Oh, then you just need an ring, pinion, and master install set.
My first 97 2.3 came with a 7.5 with 3.27 gears. I don't mean to thread Jack but thought I'd mention to adsm.
Add to this that most people who ask about taller ratios (without explaining why they want them)
suffer under the common (But mostly wrong) belief that taller gears will get them better mileage. (Incase you need it spelled out, you won't)
That's great. For a 97.
Last time I looked through the axle ID coding in my 1987 manual the available gears were 4.10, 3.73, and 3.45.
When I make "blanket" statements, like that, they usually only apply to my knowledge of the model years in question.
If you really want to spread out I can think of a number of years the Mustang came with 3.55 gears in a 7.5 axle. Most people aren't going to think outside the box and go look for parts from very different years or other cars.
