Need help lowering my '83
Joshuathedestroyer
10+ Year Member
I'm looking to lower my 1983 ford ranger, the only problem is the front. I'm only flipping the springs in the back, What can i do to the front to match the rear?
if your keeping it cheap, just chop a coil off the front and call it a day. but don't use a torch, only something like a cutoff wheel/sawzaw, or else you'll weaken the springrate. and also if you cut to much you may have to get camber bushings so you don't go through tires
but dont cut too much or youll end up with the nose one the ground. try 1/2 coil intervals
