- Oct 1, 2008
- san diego, ca
looks like your off to a great start. its awesome to see someone start with a plan and get moving on it so quickly. good luck with the build
did you replace the front and rear main seals and take care of the kdp?
i didnt lock tight those bolts...which i wanted to lol, but none are lose yet. just make sure you got the seals with the sleeves, one of the guys on the forum (including me) tried using a non sleeved front seal and wondered why it wouldnt fit![]()
returned for a sleeved one with no problems, i went to allied diesel over in freehold, guys were great help getting parts and troubleshooting some things as i came to buy more parts. you have a build thread going on 4bt?
Yeah, i got the sleeved one.
One of the guys on here works in the parts dept at a Cummins dealer in South Plainfield. He said he'll get me a good deal on parts.
I've already got a bunch of new parts in stock at work, we work on a bunch of 6bts. They are used in some forklifts.
you already have the front crank seal? if not i can have it for you monday, its a kit, seal, dust shield, and install tool. i can get the speedi sleeve too![]()
No I dont have the front seal yet. I need to get it.
I've got the rear main and the front cover gasket here.
I need the front seal and the oil line for the turbo. I know I'll need a few other things too. (pan gasket, t-stat, ect) But we can talk about that tomorrow, when you pick up the m5od swap stuff.
...its well over 300 k working to 400 now so its days are numbered.i found the 4bt too loud and vibration prone to fit my taste. but it certainly is more economical to operate.
with the manual trans i am confident you will be satisfied with the fruits of this work even as involved as it is....
