what kind of lift should i get???
We can agree to disagree. "Cali lift" ends as a result of the suspension components used in desert trucks to allow for a sick amount of travel. Not to look like a freakin stinkbug. What truck have you looked under that had 4 shackles? a revolver setup?
And an S10 is a horrible platform to build off of, IMO. Get another Ranger.
ya i know, but same look... ive seen many samurai's with four shackels.
i want another 1st or second gen ranger but i gotta make do with what i got. a crappy s10, cause i sold my ranger so i could start from the ground up on a truck... s10 build is better then a tweaker ranger build, haha
This is not S10 Station.
4 shackles would probably create a very unstable suspension due to the fact that there would be no way to locate the axle. on the front of the spring you have a mount and the rear has a shackle. i think longer shackles lower an s10 anyways. and yes spindle lifts are good as far as lifts go.
i did some research. longer shackels lift 1st gen s10's and lower newer ones
The bolt pattern is still not the same. My friend had two of those piles of garbage. I tried to loan him a spare tire, lug spacing is not the same.
oh, and Samurai's have leaf springs at all for corners, thus shackles at all four corners. not true with rangers. but, it's your truck and if you want shackles up front, then i say go for it! don't think i'll wait for the pics of that build though.
I would have taken the time to return a Ranger to stock and then built it from the ground up before I bought an S-10. If i'm not mistaken, the 2.8 in your S-10 is the same my friend has in his 86 Jeep Cherokee. Never much power, not much fun.
like i said in my other thread. im trading my ranger for a stock ranger stx :yahoo: i have both the ranger and s10 as of now. i was just trying to figure out what i should do... thank you. im gettin the stx friday and sellin the shit10 (nick name at my house for the s10 is "the terd")
