EBC Brakes logo
EBC offers replacement rotors for the 1998 and up Ranger and replacement pads for the 1987 and newer Ranger.
EBC Brake Rotor
      EBC Brake Pad
Here is the install of EBC USR rotors and EBC Yellowstuff pads onto my 2002 2wd Ranger Edge.
First jack the truck up and place it on a jackstand
First jack the truck up and place it on a jackstand. Then remove the wheel.
unbolt the caliper from the bracket
Next go ahead and unbolt the caliper from the bracket, then make a little hanger to hold it out of the way. Do not let it dangle by the brake line.
Unbolt the caliper bracket
Unbolt the caliper bracket and place it out of the way.
Remove the dust cap, cotter pin, and retaining bolt
Remove the dust cap, cotter pin, and retaining bolt. Now pull the disk off of the spindle. Wipe all the old grease off of the spindle also.
new bearings come with new races
The new bearings come with new races also; these disks already have races in them so you can discard the races that came with the bearings.
EBC rotor with new bearing
Pack your new inner bearing with wheel bearing grease, there are several ways to do this but by far the easiest is to use a grease gun and buy a cheap bearing packer attachment which will run you ~$10. Also put some grease in between the bearing race and the bearing itself.
Install your new seal over them
Install your new seal over them.
Apply a decent amount of grease to the spindle and slide the new rotor on
Pack and install your new outer bearing just like the inner. Apply a decent amount of grease to the spindle and slide the new rotor on. Now put the old washer back on and thread the retaining bolt on by hand.
Here is the procedure for tightening the retaining nut.
With it tightened install the little piece that keeps it from coming out.
Install a new cotter pin.
Now put a nice amount of grease onto all of it
Now put a nice amount of grease onto all of it.
Reinstall your dust cap
Reinstall your dust cap.
Reinstall the caliper bracket
Reinstall the caliper bracket, I used a little bit of blue Loctite on the bolts since they were pretty loose when I took them off.
Put the new pads in place
Put the new pads in place.
Put the caliper back on and bolt it back down
Put the caliper back on and bolt it back down. You will have to most likely push the pistons back in to get it to fit. This can be done by placing an old pad over them and then using a C clamp to push them back in. Be careful, brake fluid may come out of the reservoir when you do this.
Now reinstall the wheel and repeat on the other side. Now is a good time to replace your brake fluid also, but the rain stopped us from being able to do that today.
The proper way to bed these in according to EBC is to go from 40mph to a complete stop five times with one-minute intervals in between and apply more brake pressure after everyone. Be sure to do this on a closed road or a road with no traffic.
Links:
 http://www.ebcbrakes.com/
About The Author
