Overview
This article shows you how to replace your Ford Ranger torsion bars with coil-overs.
First Of All, What’s A Coil-Over?
“Coil-over” is short for “coil spring over shock”. It consists of a shock absorber with a coil spring encircling it. Many of today’s vehicles are built with struts instead of springs. The strut acts as the shock, as well as the spring that holds the vehicle up. The real difference between coil-overs and struts is that coil-overs are adjustable, and struts are not. Also, in some cases the strut itself can act as the upper control arm.
1998-2011 Ford Ranger Coilover Conversion
Why Would I Need Coil-Overs?
There are two main reasons to justify a coil-over conversion on a torsion bar equipped Ford Ranger:
  1. To get rid of low hanging torsion bars on a lifted Ranger
  2. To get a smoother ride
Low Hanging Torsion Bars
If you perform a 4-inch suspension lift on your 1998-2011 Ford Ranger, you’ll also have to lower the mounting point of the torsion bars. These hang further down than the radius arms on earlier Rangers. Dragging torsion bars over obstacles can lead to suspension failure. A coil-over conversion removes torsion bars and mounts, reducing the risk and providing more ground clearance.
1998 Ford Ranger 4x4 with torsion bar suspension
To Get a Smoother Ride
This is subjective. Some conversions improve ride quality if the stock torsion bars and shocks are worn or if the owner has cranked torsion bars for lift without upgrading shocks to match.
Is This a New Idea?
The idea of swapping torsion bars for coil-overs has been around for a while. RCD Suspension offered a 5-inch lift for 1998-2002 Ford Rangers with coil-overs. Modern DIY kits and custom setups are based on those old designs. After RCD stopped producing kits, Superlift remained the main manufacturer offering bolt-on suspension lifts.
RCD Suspension 1998-2002 Ford Ranger 4WD 5-Inch Suspension System
Installation & Brackets
These conversions usually require welding to reinforce the upper shock mount using gussets. Upper and lower mounting brackets can be purchased online or custom fabricated.
Coil-overs with upper and lower brackets
Welding the brackets
Choose the Right Coil-Over Shocks
Three types of coil-over shocks exist: Emulsion, Piggyback, and Remote Reservoir. Most applications will work fine with 2.0 emulsion shocks. Upgrades from Superlift or Rough Country kits will require longer coil-overs. See instructions linked below for exact dimensions.
Coil-over shocks types
Extended Eyelets
All lifted trucks require extended eyelets to prevent the shock body from contacting CV boots. Do NOT use these on stock height Rangers.
Extended eyelets
Choose the Right Coil-Over Springs
Stock RCD kits used 650lb springs. Extended cabs or heavy front accessories may require 750–800lb springs. Spring length depends on conversion type: 12″ for Superlift 4-inch lifts, 10″ for stock or leveled trucks.
Adding Longer Brake Hoses
Dorman H38894 hydraulic brake hoses fit directly for this conversion, replacing stock lines that may interfere with coil-over brackets.
Dorman H38894 Hydraulic Brake Hose
Bump Stops
Factory bump stops must be trimmed to fit coil-overs. Use Eibach Micro Cellular Foam Shaft bump stops to prevent deflection and CV damage.
Eibach bump stop
Limiting Straps
Required to protect CV joints and shocks from overextension. Later Superlift kits include these straps, which can be reused.
Where Should I Buy Coil-Overs and Brackets?
Last Updated:
About The Author
Jim Oaks is the founder of The Ranger Station, one of the longest-running Ford Ranger enthusiast communities on the web. He has spent over three decades owning, modifying, repairing, and driving Ford Rangers on the street, trail, and cross-country routes.
Since launching TheRangerStation.com in 1999, Jim has documented thousands of real-world Ranger builds, technical repairs, drivetrain swaps, suspension modifications, and off-road tests contributed by owners worldwide. His work has been referenced by enthusiasts, mechanics, and off-road builders looking for practical, experience-based information rather than theoretical advice.
Jim’s hands-on experience includes long-distance overland travel, trail use, drivetrain and axle upgrades, suspension tuning, and platform comparisons across multiple Ranger generations. The content published on The Ranger Station is grounded in first-hand experience and community-verified data, not marketing claims or generic specifications.
