Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 01-01-2011, 10:16 AM   #1
bhawk
Vehicle Year: 1994
bhawk is on a distinguished road
Default how does idle air control valve work?
We are plagued by the high idle condition that many ranger owners seems to have. I've read many threads on this forum on the issue but none really address my question. How does the device work?
It seems from my looking at it off the truck, when it is disconnected, the default position is to block the passage so no air can by pass the throttle plate and get into the intake. I assume that when it is connected to voltage, the solenoid pushes against that rod and opens the passages somewhat. Correct?
So, when the truck is cold and you're starting it for the first time, does it need air and therefore the solenoid needs full voltage to push that plunger open all the way?? or is it the opposite, on a cold start there should be no voltage at the solenoid so that it blocks air to the engine?
I'm really trying to figure out why disconnecting the IAC after the truck is at operating temp causes our idle to move down from a high of 1000 rpm to a real nice 650 rpm. But with the IAC disconnected, it is very hard to start and if it does, you have to hold the gas pedal down to hold it at 1000 rpm.
bhawk is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 01-01-2011, 11:22 AM   #2
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ext Cab, 4WD, Auto, 4WABS, AC, 140k/90k.
modelageek will become famous soon enough
Default
I cant help you with how the iacv works but I was wondering if you checked/changed the ECT sensor and is the iacv new?
__________________
2004 Ext Cab, 4WD, 4.0, Auto, 153k(engine is out of a 2009 Ranger with 95k) Mileage readings as of 5/14/2017
2004 Ford Ranger Edge, Ext Cab, 2WD, 3.0, 5 speed, 116,000, AC. (SOLD)
1999 Ford Ranger, Reg Cab, 2.5, 5 speed, 2WD, no AC, 150k (SOLD)
modelageek is offline   Reply With Quote
Old 01-01-2011, 11:29 AM   #3
Ranger44
Ranger44's Avatar
Vehicle Year: 1995
Vehicle Make: FORD
Vehicle Model: Explorer
I use this vehicle for: Riding mad max style......
Ranger44 will become famous soon enough
Send a message via AIM to Ranger44
Default
The IAC is controlled by the computer. The computer takes many other inputs from other sensors, and the IAC plunger is adjusted accordingly to adjust engine idle.
The IAC has a stepper motor. It has several different settings like steps that it positions to with different voltage applied to it by the PCM.
So it should move, and not to just one extreme or the other. And if the idle falls when unplugging it, it doesn't mean it's bad. It could just be doing what it is supposed to, according to the other sensors input into the PCM (MAF, ECT, HO2S's(oxygen sensors), etc).
IAC's usually get dirty, sticky, and clogged with carbon. You can try to clean it and the passages leading to it. Also, they usually make a whining humming sound when going bad.
High idle is also a symptom of a false reading ETC (trying to warm the engine up....constantly with a high idle), or a vacuum leak (or just false incoming air reading from the MAF).
Try unplugging the MAF and ETC, see what happens.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark.
Giddywomp Offroad & Fab
Ranger44 is offline   Reply With Quote
Old 01-01-2011, 04:45 PM   #4
bhawk
Vehicle Year: 1994
Default
thanks for the advice.
The engine coolant temp sensor is new, replaced it couple months ago. No change in idle then. Put a new air intake temp sensor in the intake chamber and no change in idle. Changed the MAF sensor couple days ago with one that works on another ranger. No change. Changed the TPS to one off a truck that worked, no change. When we unplug the IAC it idles down to 650 or so, real nice, but once it is plugged back in, it goes to 1000 rpm at idle. When shifting (manual trans) the rpm's hold at what they were when we hit the clutch, no quick drop in rpm's on shifting which is the real aggravation here.
I guess we'll have to bite bullet and buy a new IAC. Tried a used one yesterday and a little change for the better, but not much.
Old 01-05-2011, 10:34 AM   #5
Ranger44
Ranger44's Avatar
Vehicle Year: 1995
Vehicle Make: FORD
Default
If the RPM sticks, I'd suspect either of 2 things.....
Vacuum leak after the MAF or IAC.
__________________
Old 01-05-2011, 10:53 AM   #6
bhawk
Vehicle Year: 1994
Default
Thanks guys for the opinions. I've searched high and low for a vacuum leak and can't find one. I recently changed the IAC to another used one off an old parts truck my dad has. It brings the idle down to 900 rpm at operating temp. So that isn't too bad. I suspect if I bought a new IAC it would come down even more.
On a disgusting note, I live in Canada and I went to price out a new IAC at Napa here. They sell Echlin and quoted me 209 bux plus 12 percent tax. I go on the Napa USA online site and the same IAC by Echlin sells for 83 bux. Go figure. We constantly get gouged by parts suppliers here in Canada and this is just another example.
He also quoted me 109 bux for a new IAC by Standard, but he seemed to imply it wasn't the best quality, he pushed me to the Echlin one. No way am I spending 209 when I can pick one up in ND on my next trip there for 83. Thanks again boys.
Old 01-07-2011, 01:17 PM   #7
backroad101
backroad101's Avatar
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger XLT SuperCab
I use this vehicle for: 2nd vehicle / truck stuff.
backroad101 will become famous soon enough
Default
Here is what my IAC was doing when it was going bad
__________________
99 Ranger XLT 4DR 4wd 4.0L OHV, Auto.
backroad101 is offline   Reply With Quote
Old 01-08-2011, 11:51 AM   #8
AaronC47
Junior Member
Vehicle Year: 93 94
Vehicle Make: Mazda Ford
Vehicle Model: Navajo 4WD Explorer 2WD
AaronC47 is on a distinguished road
Send a message via Yahoo to AaronC47
Default Iac ?
Hey Bhawk I didnt see anything about yr of your truck, I have a good little collection (2 or 3) IAC's here that came off of a 91, 92, 93, or 94 explorer with the 4.0. If you need one I can save you alot of money. And I know for a fact they are good and work.
Oh Hey there it is,, It says a 94,,,
Last edited by AaronC47; 01-08-2011 at 11:53 AM. Reason: I was momentarily unable to see the writing on the screen, I think I had a brain fart.
AaronC47 is offline   Reply With Quote
Old 04-17-2011, 08:00 AM   #9
bhawk
Vehicle Year: 1994
Default
To update this thread, the high idle that bothered us for a long time has been solved. It was not the IAC. It turned out to be a leaky lower intake manifold gasket. After replacing the gasket, the idle goes down to 700 rpm or so hot, and never exceeds 1150 or so on a cold start. Runs and drives so much nicer, and fuel economy has improved significantly.
You cannot discover a vacuum leak at the joint between the lower intake and the cylinder head with propane or starter fluids, or the like because that joint is UNDER the valve cover gaskets. I discovered that on tear down. Spraying those products will show you if you have a leak at a vacuum hose or fitting, or a leak at the join between upper intake and fuel rail manifold, but they are of no help with the key joint under the valve covers.
Thought I'd close this topic with the solution that worked for us.
Old 09-03-2014, 02:38 PM   #10
dpzum1
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger Edge, 4 liter 5 speed manual
dpzum1 is on a distinguished road
Cool IAC problems
Have the same issue with mine. Tried everything, then I got an idea, so I fashioned a gasket with 1/4" holes over the spots where the larger holes are, and it works fine now. Not sure I'll let this be permanent, but until I can buy a new IAC, it's gonna stay.
dpzum1 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
