Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 06-06-2010, 08:36 PM   #1
coulrophobian
Junior Member
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Ranger
coulrophobian is on a distinguished road
Default Valve adjustment 89 2.9
Does anyone know the specifics for valve lash adjustment on an 89 2.9L? I've just finished the break-in period after a top-end rebuild and seem to remember that it was 1 full turn after zero lash, but my Haynes says 4.5 after zero... THERE'S NO WAY THIS IS CORRECT!!! Please help.
coulrophobian is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 06-06-2010, 09:38 PM   #2
59flatbedford
Vehicle Year: 1989
Vehicle Make: ford
Vehicle Model: ranger
59flatbedford is on a distinguished road
Default
i think its half to three quarters of a turn after zero. there is an article in the tech section under head jobs that details it.
59flatbedford is offline   Reply With Quote
Old 06-06-2010, 10:10 PM   #3
coulrophobian
Junior Member
Vehicle Year: 1989
Vehicle Make: Ford
Default
Ah ok. I thought I had read it there but couldn't find it earlier. Thanks.
Old 06-06-2010, 10:11 PM   #4
Big Jim M
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger FX-4 level 2
I use this vehicle for: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Big Jim M will become famous soon enoughBig Jim M will become famous soon enough
Default
One turn seems a lot. I always adjust 1/2 to 3/4 turn. It has worked out well for me.
Big JIm
Big Jim M is offline   Reply With Quote
Old 06-06-2010, 10:17 PM   #5
coulrophobian
Junior Member
Vehicle Year: 1989
Vehicle Make: Ford
Default
Just read it and it says 1 1/2 to 1 3/4 turns after zero. Not only have I finished the break-in period after rebuilding the top end, I hear a "knock" (not a "ping") at higher RPM and suspect that I might have one that is a bit loose. It's quite sporadic, so we'll see if this does the trick. Also, what do I re-torque the head bolts to after the break-in period??
Old 06-06-2010, 10:48 PM   #6
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
I use this vehicle for: DD tow boat
kimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to behold
Default
In my chiltons cold adjust it turn the screw out till you feel lash the back to touching then in 1-1/2 turns
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 06-07-2010, 12:19 AM   #7
coulrophobian
Junior Member
Vehicle Year: 1989
Vehicle Make: Ford
Default
How about re-torquing the head bolts while I have the valve covers off? Hayne's says 22 ft. lbs., 55 ft. lbs. then an additional 90 degrees for rebuild, but just to re-torque after break-in. RE-TORQUE TO WHAT, HAYNE'S!!???
Old 06-07-2010, 02:23 AM   #8
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Default
I believe you just need to retorque the intake manifold after the warmup the teck library under 2.9 V-6 dont specify a retorque on the heads just the manifold.
__________________
Old 06-07-2010, 10:18 AM   #9
Psychopete
Psychopete is just really nicePsychopete is just really nicePsychopete is just really nicePsychopete is just really nice
Default
1-1.5 turns after 0-lash is what I remember...
I did the same procedure as what's in the tech library for head bolts on mine and never had any problems, just be sure you are using new head bolts:
Sounds like that manual would be useful to start a bon-fire with...
Psychopete is offline   Reply With Quote
Old 06-07-2010, 12:56 PM   #10
coulrophobian
Junior Member
Vehicle Year: 1989
Vehicle Make: Ford
Default
Thanks Pete, I'll take your advice... especially the bonfire part!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
