how much to fix bent driveshaft?
94ranger#22
Havasu
Nissan
5.6
SO if igured out what was wrong with my truck, the driveshaft is bent about an 1/8 inch. Any ideas on how much it would be to fix it? or should I just go to the junk yard and get one? Also how much are front wheel bearings?
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Wheel bearings usually go for about $12 a pop. As for your drive shaft, it's scrap now. The boxes they come in, and the new shafts both have a tag that says "scrap if dropped" once it's dinged, dented, or bent it's junk.
94ranger#22
Havasu
Nissan
5.6
oh alright. What year shafts will bolt up? its an ext cab
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
You should be good for 90-97 if you want a 2-piece, long as it's an X-cab. But since you already need to replace the shaft, great time for a 1-piece swap, I'd go 98-99 because those are a bit smaller around. Less trimming to do.
94ranger#22
Havasu
Nissan
5.6
Oh ok. Should i go to a yunkyard or get one new?
01_ranger_4x4
Michigan
4.0 SOHC
i had my stock driveshaft re- built locally with a new tube and new spicer u-joints for $100, it was bent badly when i bought the truck. they are fixable, check local axle/ drivetrain shops.
94ranger#22
Havasu
Nissan
5.6
alright i will check out some shops tomorrow thanks
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I've always been told they aren't, but yeah, if you replace the tube and get a total rebuild. By that point it's basically a new shaft though.
srteach
9
Ranger, F350
4.0L, 7.3 Diesel
If the shaft is dented or kinked, find new or new to you. If it is just arched, a good shop can straighten and balance it for about $75 - $100 in my area.
My brother had a shaft with a 3 inch deflection in it. Shop said "NO" to fixing it (didn't want liability). I've had one straightened by the same shop with no problem.
01_ranger_4x4
Michigan
4.0 SOHC
yeah they replaced the entire tube on it. it was like a brand new shaft when it came back. its been on the truck for 8 years now with no issues.
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,857
Rapid City SD
Engine Type
V8
5.0
Drivelines are definitely fixable - Inland Truck Parts (my local shop) can straighten them if they're not really bent. They can just replace the tube too. You can expect to spend around $100 having it straightened or the tube replaced versus around $250 to have a new one built.
lil_Blue_Ford
6,221
Butler, PA, USSA
4.9L
Shouldn't we be asking how he bent it to begin with? :icon_rofl:
94ranger#22
Havasu
Nissan
5.6
I think i am just going to go with the one piece swap if i can find one for cheap. if not i will have the old one rebuilt. thanks for all the input
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
At which you've hit what seems to be about the average cost of the 1-piece swap.
I'd probably do that now that I have a 1-piece in, but I wouldn't spend the money on a 2-piece shaft.
Members online
No members online now.
Today's birthdays
Mudtruggy
May Truck of The Month
