Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 05-22-2013, 11:57 AM   #1
bjdm151
Vehicle Year: 2001
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: DD
bjdm151 is on a distinguished road
Default 2.5 Oil sending unit location
I have seen this question on here quite a few times so I wanted to go ahead and post this so its here for people to see.
This is the location of the oil sending unit on a 2001 Ford Ranger 2.5L. The easiest way to access it is from below. It is a one wire sending unit located on the drivers side (left) to the rear (aft, behind) the #4 intake port (aft, farthest from the front).
Ranger Oil Sensor by bjdm151, on Flickr
http://www.flickr.com/photos/bj_moore/8780442803/
It is not a sensor at all but actually a grounding unit or switch. When the switch sees oil pressure it close and connects to ground and the needle in the gauge goes to the middle. It is apparently normal for these to start getting funky after sometime. In my case it would just not show pressure during a cold start but eventually wake up and close the switch.
It's a pretty easy fix. A deep well 13/16 socket, swivel, short extension, and a ratchet, I used 3/8" drive. Just make sure to put some teflon tape or other sealing compound on the new sensor.
bjdm151 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Reply
Bookmarks
Tags
ranger 2.5 oil sending, ranger 2.5 oil sensor, ranger 2.5 oil switch
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
