Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-31-2009, 02:01 PM   #1
helpme
Vehicle Year: 94
Vehicle Make: ford
Vehicle Model: rangerxlt
I use this vehicle for: everyday use
helpme is on a distinguished road
Default High NOX
Got a 94 3.0 Ranger and it wouldn't pass emissions. High NOX by almost double.Got 190K miles on it. Last tuneup was done at 140K. New plugs and wires. Cleaned up the PVC valve. Has no EGR. Checked vacuum with guage and its right in the middle of the green. Has a lot of local miles. Not much freeway. Seems to run pretty smooth though. Have run low test gas but have been running hitest lately. Bought vehicle new in '94 and I'm an only driver. Any ideas to get the NOX down? Thanks.
helpme is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-03-2010, 12:18 PM   #2
helpme
Vehicle Year: 94
Vehicle Make: ford
Default More...
I have never seen a check engine light on this truck (except at crankup).
Even if I leave the gas cap off. Is this a shortcoming of OBD-I?
Old 01-03-2010, 12:45 PM   #3
BeaterMan
BeaterMan's Avatar
Vehicle Year: 1985,1997
Vehicle Make: Ford
Vehicle Model: Ranger, f150, bronco
I use this vehicle for: beater/ dd/ donor
BeaterMan is on a distinguished road
Default
you said it doesn't have a egr? did it have one at one point and someone omitted it or did it never have one? that could cause high NOx and so could ignition timing.
BeaterMan is offline   Reply With Quote
Old 01-03-2010, 08:26 PM   #4
graff104
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Everything
graff104 is on a distinguished road
Default
Quote:
says he is the bought it new in 94. Try pulling the codes just cause the light isn't on doesn't mean there is not something stored that might point us in the right direction.
graff104 is offline   Reply With Quote
Old 01-04-2010, 08:37 AM   #5
helpme
Vehicle Year: 94
Vehicle Make: ford
Default
I'll do that. Here are the numbers. On the 25/25 test it read 2407. Max GA. legal is 1121. On the 50/15 test it read 2432. Max GA. legal is 1227. So they're real high not just a little bit.
Old 07-11-2010, 09:13 PM   #6
macarchie
Vehicle Year: 1991
Vehicle Make: Ford
macarchie is on a distinguished road
Default
Was this issue resolved? I have the same problem with a '91 (no EGR and high NOX). Curious to know what the answer is.
macarchie is offline   Reply With Quote
Old 07-11-2010, 09:55 PM   #7
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Vehicle Year: 89
Vehicle Make: Ford
Vehicle Model: Ranger S
I use this vehicle for: everything
BRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of light
Default
turn the ignition timing down when you go to get it tested..
and you are SURE you have no vacuum leaks
BRUTUS_T_HOG is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
