kp3ft
- Jul 7, 2009
- Reaction score
- 0
- Automatic
I've done a ton of searching on the web and in my Haynes manual, but am only more confused. I'm not sure where the OBD2 plug is on my 1996 B2300. I looked under the dash and found what may be the plug but it's unlabeled and only has two pins available in it. Also, isn't the check engine light supposed to come on normally when the ignition key is turned on (without starting the motor)? From what I've read, it's supposed to, but mine doesn't come on at all. It would be nice to access the computer to see if any sensors have problems or whatever, since my truck gets awful fuel economy, but if I can't access it then I'm getting rid of the thing. I've had it with newer vehicles, they are getting harder and harder for the homeowner to fix.
