Horn not working
mulishiaranger
4.0L
When i push on the sterring wheel my horndoesn't sound, but it clicks? It might just be unpluged, or i'v blown a fuse... but i can't even locate the horn ha. Has this happened to anyone else? Where is my horn?!
okietheranger
santa rosa
ford
5.0 HO
ive had that problem once. after i check everything from fuses to the horn i found there is a relay in the dash by the ash try that was bad how did i find it? i fallowed the clicking :)
dennis461
2
Waterford, South Jersey
1991
Jeep
3.0l
hammer
Have someone hit the horn with wrench or hammer while holding down the horn button.
Might fix it, mine needs the "adjustment" often with mud getting in...
:D
cocoasranger
5
south central Pa.
Run 12v directly to the horn. If it does not work your horn is bad and you simply replace it.
mulishiaranger
4.0L
It clicks on the passenger side, so i must be the horn, cause my fuse panel is to the left of my dash, and the fuse box is driver side under the hood. Thanks boys.
red85
7
Kitchener, Ontario, CANADA
306 ci
"horn broken. Watch for finger." LOL couldn't resist.
bergz0
8
nj
ford
Engine Type
2WD / 4WD
leveling kit
31x10.50x15
on my 93 ranger the horn was actually on top of the drivers side inner fender (the plastic piece) mine was shot. so i bought a "bad boy" air horn re-wired it on the right side right in front of the coolant/washerfluid resivoir. hope this helps
jay jigless
Michigan
2.9L V6
what if there is no clicking when you press the horn? when mine went out it was like it worked one minute then just stopped one day? im really hoping that the button is not bad. but where exacly is the relay by ash try at? i havent checked that yet.
Scrambler82
11
SoCal
Ford/EDGE
3.0
2WD / 4WD
4.5" SL
Total Drop
WWWhhhaaattt !?!
33 x 12.50
Take a multimeter set for 12 volts DC and see if there is power at the horn when the button is pressed.
If not work you way back to the relay, fuse, horn switch until you locate where the power has stopped.
Replace the component that isn't allowing the power to flow... end of story.
twinky
Tampa, Fl
4.9 st8 6
jay,
try the wire connection at the hornit might be loose
thats what happened to mine:D
too much mud :icon_twisted:
-Twinky
PMitchell08
33
Ohio
3.0L V6
Horn Troubleshooting: Solved!
Wanted to bring one of these "horn not working" threads back to life...
On my 1998 3.0L Ranger, the horns hide underneath the fender under the battery, you can't see them from the top or the bottom, there is a single nut that holds a bracket with both horns attached to it to the bottom of the fender, right between the driver headlight and the battery. When mounted, you can just barely see the positive lead that runs into the main wiring harness along the radiator support.
When mine stopped, the first thing I did was add WD-40, jiggle the wires. It magically works again for 2 months.
It stopped again, gave it the same treatment: nothing. So, I disconnected the wires gave it a more thorough cleaning and inspection, connector looked okay, but still no horn.
I tried both the fuse and the relay, which on the 1998 are under the hood, number 10, a 15 amp fuse, and number 7, a 5 prong relay. When both are in place there is an audible 'click' at the relay when the horn button is pressed, when either one is removed, the click ceases. If the relay is replaced with a known good one, the click is the same, still no horn. This leads me to believe that both the fuse and the relay are good.
Using a piece of speaker wire, I wire the positive lead of the horn direct to the positive battery terminal, upon contact I get an immediate and hearty tone from both horns. This shows that the ground is good, as are the horns, and therefore the problem is somewhere in the positive lead from the relay to the horn.
Though I was hesitant to do permanent surgery to remove the connector, I knew this was now the most likely problem. upon removing the connector and cutting into the wire, I could see the obvious corrosion that was just under the wire insulator. After cutting another 1/4 inch, I was into clean copper again. I stripped the wire, twisted it around the blade on the horn, and suddenly, with a press to the steering wheel, my horn is back to telling kids on cell phones to quit drifting into my lane.
I hope that wasn't too long winded, and I recognize that this thread has been dead for years now, but I wanted to post just to help out anybody who was looking for the answer here like I was and didn't get quite what they needed from the previous posts.
Members online
Shran
April Truck of The Month
