MikeMcC
- Aug 28, 2007
- Reaction score
- 0
- Age
- 39
- Automatic
Gentlemen,
I am in the process of installing a 4 channel amp in my truck. The puropse of wiring this amp is to power all 4 door spears inside the truck. Initially I had planned to use new speaker cable to all 4 speakers. Upon actually trying to run the wire I have pretty much given up. It's a huge pain in the rear to route the wire through the factory cable routing.
I have looked all over every ranger forum out there and I can't find this answer. I want to wire it up to the factory speakers. I was wondering if cut the "factory wiring harness to head unit harness" and wire my speakers into the corresponding wires on the factory wiring harness adapter end, will that work?
Again I'm talking about cutting up the head unit to factory adapter and wiring the speaker cables from my amp to the factory wiring harness adaptor that would normally adapt to a pioneer HU. That would in effect do the same thing just use the factory wiring correct?
Once again I appreciate all the help!
