Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Suspension & Armor > Fabrication
Fabrication Bumpers, sliders, cages, flatbeds, tube work, etc.
Reply
Thread Tools Display Modes
Old 11-17-2008, 05:03 PM   #1
ozziemo27
June 2010 OTOTM Winner
ozziemo27's Avatar
Vehicle Year: 1999/1984
Vehicle Make: Ford
Vehicle Model: Ranger(s)
I use this vehicle for: Offroad/Daily Driver & Future Project
ozziemo27 is a jewel in the roughozziemo27 is a jewel in the roughozziemo27 is a jewel in the rough
Default Body Lift Bolt Trouble! Help!
Hey folks, I'm having a big problem that is preventing me from completing my body lift. Problem: the 2 front bolts that mount the cab to the frame are totally and completely rusted stuck. i broke the head of the drivers side bolt accidentally, I didn't even wrench on it that hard at all! what should I do concerning that one? I don't think the nut is welded on..... Or is it? Its the only damn thing that is preventing me from continuing. I live in michigan so, yea, rust is a major problem! I have doused it in liquid wrench and it still won't move at all!
-Jordan
ozziemo27 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 11-19-2008, 11:16 AM   #2
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
I used an impact wrench on mine, they came right out. You might have to just break it, then jack the truck up out of the way and try to remove it.
Then break out smokey the blue flame wrench to get it apart out of the truck... fwi at least on mine the nut was part of the bushing so if you ruin it you will need new ones.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is offline   Reply With Quote
Old 11-19-2008, 04:31 PM   #3
ozziemo27
ozziemo27's Avatar
Vehicle Make: Ford
Default
i wailed on it for at least 20 minutes with an impact wrench. I cut the other head off of the bolt and exposed the rest of it. I am going to drill both out, shouldn't ruin the nut if i center it perfectly, appreciate the input
Old 11-19-2008, 05:28 PM   #4
Joe_Roofer
Joe_Roofer's Avatar
Vehicle Year: 1990ish
Vehicle Make: Ford
I use this vehicle for: playin'
Joe_Roofer is on a distinguished road
Default
is it a nut or a clip? I just replaced the bed on my truck...Allready had a body lift. The bolts are metric m12 1.75 coarse thread (but you probably have new bolts) Just kill that bolt and get it out.
__________________
1990 Ranger, '96 bed, 3" body lift, Belltech 6400's, 2" coil spacers, BFG 31's, Warn manual hubs, C-clip eliminator, Powertraxx no slip rear locker & XRC8 winch.
Quote:
Originally Posted by gwaii View Post
not photoshop....sawzall
Joe_Roofer is offline   Reply With Quote
Old 11-19-2008, 08:34 PM   #5
ozziemo27
ozziemo27's Avatar
Vehicle Make: Ford
Default
they are definately nuts, by what do you mean, "kill it"? drilling it out or....?
Old 11-20-2008, 05:40 PM   #6
Joe_Roofer
Joe_Roofer's Avatar
Vehicle Make: Ford
Default
Just kill 'em.... No, serioulsy,
I've never done a body lift on the cab but 3 of the six
bed bolts were so rusted/busted when I took mine off that
I lifted the bed out of the way (once the heads were off) cut 'em off flush with the frame
and hammered them out with a drift.
Hope this helps.
__________________
Old 11-20-2008, 07:30 PM   #7
85_Ranger4x4
December 2013 OTOTM
Vehicle Year: 1985
Vehicle Make: Ford
Default
Quote:
The bed has clips, and bolts right to the frame with no rubber bushings.
__________________
Old 11-20-2008, 09:43 PM   #8
ozziemo27
ozziemo27's Avatar
Vehicle Make: Ford
Default
Hope this helps.
I drilled one all the way through today after I found a few of my dad's really good bits, went through so damn easy it was amazing, I am going to get some more of the right size so i can finish drilling it out, then I have to drill the other side out! hopefully i can get it as straight as i did the first time, eyeballing it, its kinda tricky with a 4-5 inch bolt!
Old 11-30-2008, 09:40 PM   #9
kozak
kozak's Avatar
Vehicle Year: 97,79,87
Vehicle Make: Ford
Vehicle Model: Explorer, F250, Ranger
I use this vehicle for: Daily Driver & Bush Beast
kozak is on a distinguished road
Default
Same thing happened to me with my Explorer body lift. Funny thing is, my Explorer has literally no rust underneath, and is a 93. I ended up having to take a torch to both the front mounts. Every other mount was easy. Then after I got the front to ready to go, the bolt holes wouldnt line up, so I had to break out the come a long. They can be a big pain in the ass, but well worth it in my opinion.
kozak is offline   Reply With Quote
Old 12-28-2008, 12:16 PM   #10
robmurt90
robmurt90's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Daily Driver & Occasionally Play
robmurt90 is on a distinguished road
Default
When I did my explorer which has virtually no rust underneath, I soaked them with PB Blaster for two weeks. Then when I did the body lift I used an impact gun. Even with 500 ft/lbs a couple of the s.o.b.'s wouldn't budge.
__________________
1994 Ford Explorer
9" Lift, 4.56 Gears, Locked Rear, 36x12.5
Intake, Exhaust, MAF, TB, Chipped, SOLID Diff Cover
Down for Construction (More TTB Lift, New Engine, 38.5" SS)
robmurt90 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
