what RPM is to much?
roughranger
my trans is shifting at 4000 RPM is it this to high for one of these motors? it is a rough/tough truck so it will be in 4 low mostly but dont want to pop a motor! thanks rough
4byRANGER
FORD
3.0 turbo
what motor does your ranger have? 3.0, 4.0, 2.3?
my 95 has a 3.0, i know these engines love high rpms. when im mobbin in town i try and keep the rpms at 2,800 to 4,500. sometimes i hit the rev limiter which would be a little higher than 5,000 when im tryin pass or just go fast.. :shout: <- me yelling GO!!!!!! and shaking the wheel when the rpms are too low
roughranger
2.8 sorry i didnt say that b4! It is carbed with points ~ rough
Big Jim M
30
Austin
4.0
Roughrider does it wait till 4000 to shift or is that when it shifts with the skinny pedal on the floor? If it will NEVER shift till 4000 that is bad.. But if it shifts at 4000 with the pedal at full throttle that is too low!
Big JIm
roughranger
i can be running it half throttle and it wont shift so i have just been winding it out to the 4000 and then letting off a little for it to shift. i havent tryed to shift it manually from 2 nd to drive to overdrive i might try tthat and see if it is just somethin with the kick down. any help is MUCH appreciated guys i am planning on running this thing on tuesday. rough
4byRANGER
FORD
3.0 turbo
i sorta had the same problem i guess, i switched out my tcase with an older one. the speedo was not working and the shift points were way tooo high, i had to use my old speedo gear out of the old tcase to correct this..
if its an aod tranny i could see that having somehtin to do with it..
Big Jim M
30
Austin
4.0
Rough rider sounds like a "detent rod" needs some adjustment.. In most modern vehicles that rod is now a cable .. If when opening the throttle the cable gets SHORTER then you need to make it longer from idle up.. If it gets LONGER then the opposite is true..
These detent cables/rods have control over when a tranny shifts..
It will be the OTHER cable from the throttle.
Big JIm
4byRANGER
FORD
3.0 turbo
OH SHIT i totally forgot.. check your throttle cable by the pedal, if it has alot of slack or if your gas pedal looks way lower than your brake. (pushed in more) theres a section in the tech library that shows you wht to do..
i just used small zip ties and put em between the top of the spring and the cable end itself.. worked wonders, now i dont have to push the pedal the way down or thats what it seemed like.. helped with my overall shift points to, wayy more controlable
hope this helps
small ranger
Solid Axle Swap
dirty south
171 c.i. of fury
These motors can do 7000rpm before floating the valves, under load I have heard guys doing 7500rpm, so 4000rpm may be a little high for shifting but with a stock cam max torque is 2800rpm. My motor does 2700rpm @ 60mph. Take it for what its worth
Staff online
Members online
Shran
April Truck of The Month
