Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 07-27-2008, 01:24 PM   #1
ihatemybike
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Teaching a friend how to work on his truck.
ihatemybike is on a distinguished road
Default 4R44E Help - Valve Body?
Back in 2000 my wife bought a 1997 Ranger, nice truck treated her well. Last year we sold it to a friend and we've been teaching them basic maintenance on it. Last week while performing a trans service when I wasn't watching this friend broke the bolt that holds the filter in the valve body. It's driving us nut trying to get it back out. I'm thinking about pulling the valve body so we can use my drill press on this bolt and finally get an extractor to work on it. Problem is I can't find any instructions on 4R44E valve body removal. I don't want springs or balls or anything flying away. Anybody have suggestions or know where I can find good instructions online?
ihatemybike is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 07-27-2008, 02:17 PM   #2
Bruce
Bruce's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger Super Cab XLT
I use this vehicle for: Daily Driver
Bruce is on a distinguished road
Default
The bolt for the filter goes all the way thru valve body into the case, once you pull valve body bolt should easily come out. Pulling the valve body not to bad, there is nothing that will come flying out at you or that can be lost. There is 4 different length bolts in valve body so pay close attention to them, you will have to also remove reverse servo cover in which servo may have a spring under it and it will come out no biggie though.
Torque on valve body bolts is about 100 inch pounds and it is imperative(at least to me)that bolts be torqued properly since the valve body is aluminum.
Good luck
__________________
2002 Ranger Supercab 4x4 4 door 4.0 with 4:10 gears.
Bruce is offline   Reply With Quote
Old 07-27-2008, 08:06 PM   #3
ihatemybike
Vehicle Year: 1997
Vehicle Make: Ford
Default
OK, confidence is rising. There are a lot of bolt heads, do these all have to come out?
Would still love an exploded view. I wonder if the Library has the Mitchell's.
Old 07-27-2008, 09:36 PM   #4
Bruce
Bruce's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Default
Quote:
Yep all them 10 mm head bolts have to com out..except for the silver colored ones and they just hold the brackets that that retain the solenoids.
__________________
Old 07-31-2008, 11:36 PM   #5
ihatemybike
Vehicle Year: 1997
Vehicle Make: Ford
Default Fail!
Well, I pulled 30 bolts and removed the broken filter bolt. Then put everything back the way I found it, or so I thought. I guess I messed something up, cause now reverse and neutral cause the truck to go forward.
What did I do wrong?
__________________
Aaron
Elgin, IL
1997 Ford Ranger 2.3L
(Used to be my wife's, but now a friend owns it.)
Old 08-01-2008, 12:54 PM   #6
ihatemybike
Vehicle Year: 1997
Vehicle Make: Ford
Default
Help
__________________
Aaron
Elgin, IL
Old 08-03-2008, 05:48 AM   #7
RANGER 07
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: Ranger 4x4 ,xlt,3.0 ,V6
RANGER 07 is on a distinguished road
Default
Im going to go out on a limb on this one , I'm not an expert on tranny's I 'm still learning , but could it be ..?, you messed up the DTR sensor when installing ? a.k.a as the Manual Lever Position Sensor ,(mlps), this one should be installed/disinstalled on neutral
with the neutral mark , on the inside ring , coinciding with the outer ring , and the internal ridges of it go aligned withthe keyways on the shaft.hope this helps !!
RANGER 07 is offline   Reply With Quote
Old 08-03-2008, 12:39 PM   #8
Bent Bolt
Bent Bolt's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger STX
I use this vehicle for: Breaking parts , sitting in the back lot
Bent Bolt is on a distinguished road
Default
You probably missed the manual valve into the shift linkage.
__________________
87 Ranger , a bunch of stuff including a supercharged 4.0l SOHC and 35 x 14.5 x 15 Pitbull Maddog's. Woof !
Now with C5/C4 hybrid ! And FW D44/9"
Bent Bolt is offline   Reply With Quote
Old 08-03-2008, 06:48 PM   #9
mfp4073
Junior Member
mfp4073 is on a distinguished road
Default
yeah, its probably the main selector valve. There is a spot for the selector shaft to go into.
the manual valve is on the bottom, just to the left of the solenoid with the * on it. The shaft has to go in that first groove closest to the end of the valve.
Does anyone have a better pic? I dont think I am helping.
mfp4073 is offline   Reply With Quote
Old 08-03-2008, 09:15 PM   #10
whtailhunter319
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger xlt 4.0
whtailhunter319 is on a distinguished road
Default
Try this, i used this info to replace my valve body. Good information, hope it helps! http://www.ford-trucks.com/article/i...dy_Gasket.html
whtailhunter319 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
