Go Back   The Ranger Station Forums > Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 09-02-2007, 07:47 PM   #1
88mudder
Year: 1988
Make: Ford
Model: bronco II
88mudder is on a distinguished road
Send a message via AIM to 88mudder
Default fuel pump + line
swapping a carbed 302 in my b2 which is currently the 2.9 electric puel pump in the tank. When swapping in the 302, do u run the mechanical pump on it or keep the electric pump and use a pressure reducer? If the electric pump can no longer be used how would I cap off the top of the gas tank where the electric pump goes?
Fuel lines..can i reuse the stock line and attach a fuel block then a flexible hose coming off that? Is it possible to run a long flexible hose or should i keep the hard line?
Let me know how u did yours and whats the easiest way. Sorry for alot of questions!
88mudder is offline   Reply With Quote
Old 09-02-2007, 08:23 PM   #2
v-8power
v-8power's Avatar
Year: 1990
Make: Ford
Model: Ranger
Class: 2WD street
v-8power is a splendid one to beholdv-8power is a splendid one to beholdv-8power is a splendid one to beholdv-8power is a splendid one to beholdv-8power is a splendid one to beholdv-8power is a splendid one to behold
Default
Use a fuel pump block off plate. Then i would just use your intank electric with a regulator.
__________________
My Website
v-8power is offline   Reply With Quote
Old 09-02-2007, 08:29 PM   #3
88mudder
Year: 1988
Make: Ford
Model: bronco II
Default
Quote:
Anyone have a part number or kno a good candidate for my application? Found some on summit and jegs but they were for EFI only from like 40-100 lbs..i need 5-7psi right?
Old 09-03-2007, 08:27 AM   #4
projectnitemare
projectnitemare's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
projectnitemare will become famous soon enoughprojectnitemare will become famous soon enough
Default
I can't think of any PNs off hand but you would need a regulator with a return line or you will kill the high pressure stock pumps.\\Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works
projectnitemare is offline   Reply With Quote
Old 09-03-2007, 10:20 AM   #5
Mutant Pony
Mutant Pony's Avatar
Year: 1977
Make: Ford
Model: Pinto
Engine: 2300
Class: 4x4
Used For: Mud racing/trails
Mutant Pony will become famous soon enough
Default
You can use just a tee. One side of the tee to the presure line, one side to the return line and one to the carb. If you run your float bowl empty up in the rpms just restrict the return line a little. If you blow out the needle and seat then you have restricted the return line to much.
If this is on the '88 you can bypass the high pressure pump and just use the primer pump which only makes about 12 psi.
I would just run new line from the fuel tank to the carb, Steel 3/8" line for the pressure line and 5/16" line for the return.
__________________
'84 Ranger, 351c,C6,208,EBsas."DeRanged Mudder"
'86 Ranger, 3.0swap,coil rear suspension"Black Frog"
Mutant Pony is offline   Reply With Quote
Old 09-03-2007, 07:55 PM   #6
88mudder
Year: 1988
Make: Ford
Model: bronco II
Default
so your saying to use a Tee along with the stock electric pump?
Old 09-03-2007, 08:11 PM   #7
projectnitemare
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Default
If you have 2 fuel pumps toss the high pressure one and run off the low pressure in tank pump. Use a return regulator back to the tank. If you don't have 2 pumps I would use a different pump completely, a low pressure pump for a carb.
Matt
__________________
Old 09-03-2007, 09:40 PM   #8
88mudder
Year: 1988
Make: Ford
Model: bronco II
Default
mutant pony is saying i have 2 fuel pumps but i thought all b2's only had one. I think the rangers with the big tanks had the 2 pumps.
Old 09-04-2007, 12:17 PM   #9
projectnitemare
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Default
It will depend on the year. I can't tell you for sure, my BII is an 89 but from what I remember starting in 89 is a single in tank fuel pump.
Matt
__________________
Old 09-06-2007, 10:12 PM   #10
baddad457
Year: 1989
Make: Ranger
Model: Supercab
baddad457 will become famous soon enoughbaddad457 will become famous soon enough
Default
I've used an "elcheapo" 30 gal/hr inline electric on my 89 now for over 5 years. It was enough to feed the 400+hp 3 carbed 331 I had in it at one time. This pump was made by Purolator, I have a similar one now on my 77 Comet also feeding the same 331, but this one's made by Mr. Gasket. Advance Auto Parts stocks this with the performance carb stuff.
baddad457 is offline   Reply With Quote
Old 09-07-2007, 02:53 PM   #11
88mudder
Year: 1988
Make: Ford
Model: bronco II
Default
Quote:
thanks
Old 09-07-2007, 03:28 PM   #12
Mutant Pony
Year: 1977
Make: Ford
Model: Pinto
Engine: 2300
Class: 4x4
Default
Did you ever look at your fuel system. If Your BII came with a 2.9 it should have the primer/pressure pump system. If it had the dual plug (8 plug) 2.3 then it would have a single, in tank pump.
And you don't need to spend big money on a regulator. A tee will work just fine. I've done it many times.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
