My 94' Build
WeezyLoudPack
ATL, GA
V6 4.0
Been using this site alot while building my Ranger, so I thought I should doc my build on here. So here it goes...
94' 4.0 V6, DJM 3" beams, 4" flip kit, shackle flip, cut coils,
notched frame, billet grille, new headlights and clear corners, sanded and painted frame, and other parts. Incubus wheels with 255/30/22 tires...
Started with a stock 94' V6 4.0 ext cab, threw some 24's I had on it...
WeezyLoudPack
ATL, GA
V6 4.0
Wrecked the **** out of it bout 6 months later...
WeezyLoudPack
ATL, GA
V6 4.0
Time to rebuild. Got her in the garage, and started gettin parts. Got it back together. Had cracked one of the 24s in the wreck, had some 22's, so I threw them on there.
WeezyLoudPack
ATL, GA
V6 4.0
Oh yeah, I put the clear corner lights, billet grille, and cheesy euro taillights on it back in like 2000... hahaha. Any way, I hated the look so I decide to lower her...
WeezyLoudPack
ATL, GA
V6 4.0
Took everything apart while I was waiting on flipkit and beams. Went aheade and flipped the shackles.
WeezyLoudPack
ATL, GA
V6 4.0
Went ahead and sanded and painted everything while it was apart.
WeezyLoudPack
ATL, GA
V6 4.0
Got my parts. DJM 3/4 flipkit and beams, and Belltech shocks. Started gettin it back together.
WeezyLoudPack
ATL, GA
V6 4.0
Then I did the front. Installed the beams, put the Belltech shocks on, and cut a coil off my stock springs. I aslo put a 4* camber bushing on it.
WeezyLoudPack
ATL, GA
V6 4.0
Got a carrier bearing shim kit, but still had a vibration in 1st gear. So I added as many washers that could fit. And got rid of those cheesy euro lights with a little NightShades.
WeezyLoudPack
ATL, GA
V6 4.0
Well, my ride was pretty damn rough, only had about an inch of clearance axle to frame, no bumpstops. So I ordered a notch...
WeezyLoudPack
ATL, GA
V6 4.0
Did the LED dash lights and Heat/AC lights, and put a lil flipscreen and some new 6x9s in it.
WeezyLoudPack
ATL, GA
V6 4.0
Thats as far as I got. Ill take an up to date pic tomorrow. Want a roll pan, and hopefully some body work soon...
XLTsplash
Ford Technician
160
CA
Engine Type
2.3 (4 Cylinder)
2.3L
2WD / 4WD
2WD
It's looks like your getting a lot done on your Ranger. The LED dash lights look nice and bright.
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
