Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > Mazda B-Series Specific
Mazda B-Series Specific Addressing issues specific to the Mazda B-Series trucks
Reply
Thread Tools Display Modes
Old 09-08-2012, 07:56 PM   #1
rj22beast
Vehicle Year: 1997
Vehicle Make: mazda
Vehicle Model: b2300
rj22beast is on a distinguished road
Default 97 b2300 gas gauge dont work
fule pump works, gas gauge went out, i unplugged the sending unit for the gas tank, and then the gauge rose to full, then if i plugged it back in, it wound move till i turned the key off and on again, then it wound drop to empty again, dose anyopne know where the fule pump relay would be located so i could check that and see if it got connection, all other gauges work, and there only 141k miles on it, 97 b2300 4cylinder, thanks you for the help, if anyone has ever had this problem before, i would hate to go buy parts i dont need, anyone help?
rj22beast is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 09-09-2012, 09:00 AM   #2
PanamaExpat
PanamaExpat's Avatar
Vehicle Year: 1994
Vehicle Make: Mazda
Vehicle Model: B4000
I use this vehicle for: reckless experimentation
PanamaExpat is just really nicePanamaExpat is just really nicePanamaExpat is just really nicePanamaExpat is just really nice
Default
Looking at the wiring diagram for my 94 B4000 and I am pretty much assuming that they will be very close if not exactly the same there isn't much that can go wrong in that circuit. You say you are getting fuel so it is not the fuel pump relay as that has nothing to do with the function of the gauge. You said you disconnected the sending unit and the gauge moved to full. The sender is attached to a critter called the anti-slosh module. I don't know if these go bad but since your gauge moves when it is an open circuit I will make the presumption that it is OK. So that is narrowing down your possibilities to the sending unit itself as if it were a connection going to the sending unit then the gauge movement would not occur when you unplug it. I am also presuming you unplugged the sending unit where it connects on top of the fuel tank. If not then you may have a pinched or chaffed wire grounding the gauge between the point where you unplugged the harness and the sender. So worst case scenario is that your sending unit is either stuck, the float has gone bad, or it just gave up altogether. If this is the case you have 2 options one is dropping the tank to get to the plate on top of the tank that allows you to service the fuel pump and sending unit or two lift the bed which will allow you access to the top of the fuel tank. Knowing what I know about my truck lifting the bed is much easier than dealing with the skid plates and heat shields to drop the tank.
Edited Note: Wiring diagram below.
http://imageshack.us/photo/my-images...umentclus.jpg/
__________________
"Rust never sleeps."
Just because I never finish anything doesn't mean I don't work on it.
Cheers:
PanamaExpat
AKA: Jim
PanamaExpat is offline   Reply With Quote
Old 09-11-2012, 06:55 AM   #3
rj22beast
Vehicle Year: 1997
Vehicle Make: mazda
Default
i took and lifted the bed when i was working on it, and thx so much for the help, but i think that the fule pump relay is not getting a full circuit but but i have no idea where the fuel pump relay is located on the truck i have no manual, but i took the whole fuel pump out of the tank when i was working on it and everything looked good no corrosion on the wires or anything and the float looked good, the ome"s reader red 114 at the top on full and 14 on the bottom when we moved the float to empty, im intending to think its the gauge but you cant just change the gauge i think i have to get the whole cluster becaus its on a circuit board,
Old 09-16-2012, 08:57 AM   #4
Uncle Ron
Vehicle Year: 1995
Vehicle Make: Mazda
Vehicle Model: B2300
Uncle Ron is on a distinguished road
Default
I drove for 8 years with a non-functional gas gauge. When the Fuel Filler Hose rotted out I replaced the Fuel Sender Assembly while I had the bed off. Gauge came back to life. During the first week of driving I wasn't paying attention to the mileage anymore and almost ran out of gas!
Uncle Ron is offline   Reply With Quote
Old 10-25-2012, 12:22 PM   #5
merace19
merace19 is on a distinguished road
Default
Sounds like your sender in the tank. I battled this and won just yesterday. I tried every way you can to fool that gauge in to working. I even made a 100 ohm resister to put in line to fool it to think it had fuel.
Nothing worked. I had to open the tank and change the pump so I did the sender too.
Installed new sender and pump and all works perfectly. \GET YOU A Strainer if you open the tank. My strainer was desovled in the tank. I guess from crap gas.
merace19 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
