Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Misc Electrical & Gauges
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Reply
Thread Tools Display Modes
Old 01-06-2012, 08:13 PM   #1
bert296
Vehicle Year: 1993
Vehicle Make: ford
Vehicle Model: ranger x-cab 4x4 5speed
I use this vehicle for: daily driver/ weekend wheelin rig
bert296 is on a distinguished road
Default gas gauge doesn't work?
i have a 93 4.0 the when i bought it the gas gauge would work when it wanted to otherwise it would stay at 1/8 of a tank. i thought it was a conection so off came the bed and they were a little loose, so i sodered them on still the same out come the gauge would work when it wanted to. this all happened about a month ago. now the gauge never works stays at 1/8 of a tank all the time. ive read that the float could have a hole in it? but the fuel pump and sending unit were replaced in july so i dont think its that. any ideas???
bert296 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 01-08-2012, 03:46 PM   #2
Spott
Spott's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Daily Driver
Spott is just really niceSpott is just really niceSpott is just really niceSpott is just really nice
Default
There's a good possibility that the wire that runs from the connector on top of the tank to the gauge cluster may be damaged, or broken, or grounding, or something screwy.
There's a very slight possibility that the replacement float (or the circuit board behind it) are bad, even with a new part. It's not especially common, but it happens.
Do a visual inspection of both, and let us know what you find. If you don't see anything obvious, I can give you instructions for testing everything with a meter.
Also (not accusing, but just checking) not everybody knows how to solder properly. Make sure the wires and the pins were both bright and clean, that you heated the wire and pin together (not just the solder) and that nothing moved between the time you pulled the heat away, and the time the solder solidified. A poor joint will look dull and grainy, a good joint will look smooth and shiny.
Spott
__________________
Build a man a fire, and he will be warm for a day. Light a man on fire, and he will be warm for the rest of his life.
Spott is offline   Reply With Quote
Old 01-09-2012, 12:25 PM   #3
Hawk1339
Hawk1339's Avatar
Vehicle Year: 93
Vehicle Make: Ford
Hawk1339 is on a distinguished road
Default
Intermittent connections, bad or improperly seated fuel gauge module inside the instrument cluster, bad or improperly seated slosh module inside instrument cluster.
Hawk1339 is offline   Reply With Quote
Old 01-10-2012, 01:14 AM   #4
bert296
Vehicle Year: 1993
Vehicle Make: ford
Default
Quote:
what and where are the fuel gauge module and slosh module and how would i go about changing them?
Old 01-10-2012, 08:41 AM   #5
Hawk1339
Hawk1339's Avatar
Vehicle Year: 93
Vehicle Make: Ford
Default
Quote:
The gauge modules are the individual sections that the gauges are mounted to within the instrument cluster. Depending on whether you have the plain cluster with no tach or the enhanced cluster with the factory tach, there will be either 3 or 4 module sections in the cluster. These sections plug into the cluster backplane with pins and clips making the electrical connection. These clips can loosen and/or oxidize and corrode causing the electrical connection to be broken.
The slosh module is a small circuit board, about the size of a matchbook, that plugs somewhere into the cluster. The purpose of this circuit is to dampen out large swings in the fuel level signal caused by the sloshing of fuel in the tank. It makes the gauge indicate a steady reading rather than a bouncing needle.
Before tearing the dashboard apart in order to get to the cluster, check all the wiring to the tank again, particularly the grounds.
Old 01-16-2012, 04:12 PM   #6
Martin93
Vehicle Year: 1993
Vehicle Make: Ford
Martin93 is on a distinguished road
Default
Hi I'm new to this site and have questions concerning my '93 Ranger. I'm female and invariably feel mechanics are pushing their luck with me about what's wrong with my truck. Since I'm not a mechanic I've joined this site to learn more about the problems I'm experincing w/my truck. My Ranger's gas gauge sits at 1/4 full w/engine off; EMPTY w/engine on. On a trip over the mountains the gauge started working! Back on flat desert it returned to Empty. Two repair places want to drop the gas tank..they tell me its the "float valve". Any thoughts?
I also have ABS/Emergency Brake light that comes on as soon as pressure is applied to brakes. So far I've now have a couple of ideas to present to a mechanic thanks to the knowledge of others on this site.
Thanks in advance for any thoughts on my truck problem!
Martin93
Martin93 is offline   Reply With Quote
Old 01-18-2012, 12:54 PM   #7
Hawk1339
Hawk1339's Avatar
Vehicle Year: 93
Vehicle Make: Ford
Default
Martin93
I drive a 93 and have had the ABS light coming on intermittently for several years. As near as I can figure, the most likely culprit is the ABS valve- a somewhat pricey and difficult to change item. When the ABS control detects a fault it turns on the light and shuts off the system and the brakes revert back to ordinary non ABS brakes, and that's ok by me. I'm kind of old school and don't care if I have ABS or not.
When it comes to gauge problems, the fuel level is probably the most difficult to diagnose and repair, simply because the sender is located in the fuel tank, and to access it one must remove the bed from the truck. With any gauge issue, the most common cause is a connection problem- dirty connector, dislocated pin, broken wire. Since there is like 4 or 5 connectors between the fuel gauge and the sending unit, there are a lot of places for something to come undone. in addition, the fuel level sender- the so-called "float valve"- and its wiring and connections are exposed to all the horrors of weather and road crud. The sender itself is an electrical/mechanical device that lives inside the tank, with gasoline sloshing around it, so it has a tough life as well. Now, if yours did work at some point, I would suspect the connector at the top of the sender assembly. It could be a tough reach to crawl under the truck to try to reset that connector. The fuel pump is bolted to the same sender bracket and has power wiring that goes through the same connector, and since that has apparently been working, the connector isn't totally bad.
Here's what a fuel level sending unit looks like, without the fuel pump. Everything below the disc at the top is inside the tank. Also, there is no need to drop the tank to change this- removing the bed takes 4 (or 6?) bolts and 1 connector.
http://www.rockauto.com/catalog/moreinfo.php?pk=275655
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
