4 link SAS+lift
cdawall
U.S. Military - Active
Solid Axle Swap
5
Ellsworth AFB
4.0L V6
3 link SAS+lift
its only a dana 30 I really don't want to hear how its not strong enough etc. its better than the dana 35 ifs I destroyed.
mock up height of the truck
this is with the leafs compressed+bilsteins
i need some better backspacing for the rims :/
dangerranger83
5.0 HO under the hood!!!
Solid Axle Swap
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Looks good, I would go for a longarm setup. Your going to be happy with this swap, I am with mine.
mhughes165
Solid Axle Swap
9
302
what size tire u plannin on runnin on that redic amount of lift for 33's lol
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Ok, so I won't tell you its not strong enough, but I will tell you, you are mistaken to think and say that a 30 is stronger than the 35, other than that you have a nice truck there :icon_thumby:
SVT
cdawall
Solid Axle Swap
5
Ellsworth AFB
4.0L V6
35s might take the stock block out so it looks ok with the 33s until I can afford 35s
SVT
No the diff isn't stronger than the 35 however the straight axle is stronger than the ifs.
dangerranger83
Solid Axle Swap
54
Lafayette, IN
Still sounds like an upgrade to me. If it was shafts/CV's you were breaking then this SAS may be the fix.
What type of coils you going to be running?
cliffrat
seneca,il
89 ranger 33bfg
92ranger,35bogg
looks good .t would be to tall for around here .What coils and leafs are u using? I,m about to do the same
cdawall
Solid Axle Swap
5
Ellsworth AFB
4.0L V6
jeep 3/4 leafs i can't remember the coils
cdawall
Solid Axle Swap
5
Ellsworth AFB
4.0L V6
slight update....been a bit and everything is just about done
cdawall
Solid Axle Swap
5
Ellsworth AFB
4.0L V6
legoms013
09/2013 OTOTM
OTOTM Winner
Solid Axle Swap
26
CA
4.0L V6
Any particular reason for sticking with the stock Dana 30 inverted y steering linkage?
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
OTOTM Winner
Solid Axle Swap
16
Fort Wayne, IN
4.0, 5.0
That is what I used and it worked good enough. If the jeep guys use them with upgraded tierods...
Toreadorranger
Solid Axle Swap
5
Sal
4.0L
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
but, is a shiny turd a successful turd?
how does one gauge that?
its a rapid cause of infamous jeep d.w...
good enough for now, but tears up tires still and when the cash is there getting a hi steer knuckle is advisable bud
Staff online
Members online
Today's birthdays
Mudtruggy
May Truck of The Month
