(slightly) lower rear leafs
swampyankee
15
New England
I have a '98 Ranger x-cab with a broken rear leaf spring. Still driveable as long as I don't put much load on it. But since I have to replace the springs anyway, I was thinking of dropping the height just an inch or so to make to truck easier to get bikes and stuff in and out of. I don't do any 4 wheeling so the height won't matter. I only use the 4wd for snow and maybe stump pulling LOL.
It looks like I have room on the screws to dial back the torsion bars in the front and drop the height like I did on my old truck. I will do that first just to get a proportion on how far to drop the rear.
I can go to a spring shop and have the broken leaf replaced, and they can re-arc the springs to whatever I want.
But before I do, is there a set of springs I could use that would lower the height by an inch or so? Maybe Explorer, 2wd or other spring?
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Look for the rear spacer (lift) blocks from a '08-'11 Ranger 4x4, I understand they are an inch shorter than the ones that came on your '98, and should lowers yours by that amount. You'll likely need the U-bolts to go with them also.
Alternatively, you can remove your blocks entirely, then use extended shackles to regain an inch or so.
Jacks2K4x4
New Hampshire
swampyankee, I have 2011 Ranger (4x4) and would love to swap your torsion keys and lift blocks with mine. I want to do the opposite. I want to lift mine to the pre-2008 height.
