No sound from radio speakers - 1991 Ford F250
SolidSnake84
Stephens City, VA
Hey guys, haven't posted in a long time, but i'm having a unique kind of problem with a truck i just purchased. It also plagued the previous two owners.
1991 Ford F-250, XLT. 351 Windsor and ZF Manual transmission, not that i think that would make a difference with this problem.
The guy i got it from could never get the radio to work. This isn't a joke. It has a couple year old JVC head unit, original factory in door speakers. He tried two different local radio install places, neither which could get it to work, so they never charged him for it.
Unit lights up, scrolls through the different stations, and you can put your IPOD on, I Heart Radio, whatever, it seems to work fine, but absolutely no sound comes from the speakers.
I have pulled the radio out and examined the install, they used one of those adapters that plug right into the factory harness, and there is no evidence of hacked / jury rigged wiring or anything like that. I also verified the in-door speakers were not blown out, by taking one out and hooking it to a radio in my garage.
Is there anything that can be checked before just buying two new speakers, bypassing the factory harness and wiring directly to the new head unit's harness?
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
Engine Type
2.9 V6
177 CID
2WD / 4WD
2WD
A legend to the old man, a hero to the child...
This is an old post but...
I had a 79 do the same thing. I fought with it and fought with it, come to find out it was a bad antenna wire. I swapped out the antenna and wire with one from a junkyard 77 and it worked fine. I dont know if they ground with it or what, but try that.
I imagine a 91 is setup more less the same
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Turn the radio on and then check the speaker plug for AC voltage. It should go up as the volume is turned up, but they don't peak real high, so anything is a good sign. If you have it replace the speakers. If you don't start chasing the wiring back towards the head.
Staff online
Shran
April Truck of The Month
