2005 honda accord help!
scott5640
5
Davenport FL
3.0 V6
i read a code on the car for
P0457 EVAP Emission Control System Leak:Cap Loose/Off
where is the cap located?
and what can i do to fix it
backroad101
4
4.0L OHV
Code PO-457: Evaporative emission (EVAP) system, leak detected or fuel cap loose or missing.
Did you recently get gas? Did you tighten the cap properly? Did you top off the tank after the pump clicked off? After reading the code, did you clear it? If so, did it come back? Is the car running poorly?
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Yeah, gas cap.
Staff online
Members online
Mudtruggy
May Truck of The Month
