5r55e OD light flashing
hr8882
New Jersey
Did separater plate with bonded gaskets today on the valve body.
did no other disassembly of valve body valves solonoids ECT...
Every thing kept clean and torqued exactly to spec. The trans shifts
great. very smooth. But no OD and light is flashing. OD was ok before.
The reason for the plate change was due to erratic shifts. Which
I found the original gasket damaged. Could I have not gotten one of the
solonoids plugged in correctly?
HR
Il Brutto
02/2011 STOTM Winner
MTOTM Winner
8
Huntingdon, Pa
If it ain't broke...fix it before it does.
Where did you purchase your bonded separator plate?
