fatboyf150
- Jul 25, 2008
- Reaction score
- 0
- Age
- 41
- Location
- whiteville, NC
- Make / Model
- ford
- Engine Size
- 3.0
- Automatic
my 00 ranger 3.0 auto 4x4 is having a problem cranking up. mostly when its cold. when you turn the key, its cranking over but will not start unless i hold the key for a really long time or hold the skinny pedal to the floor. once its cranked, its fine. only code the truck had was a Cly 6 misfire. not sure if there is a flow back valve in the fuel system letting it drain back or if i have other problems. I'm about to pull my hair out with this truck. any help is appreciated.
