Any known issues with swapping a '98 4.0 to an 89 BR2?
aclayton59
Near Rochester New York
B2
Engine Type
2.9 V6
Building a 4.0 for a swap
2WD / 4WD
Hi Guys,
Just picked up a 89 Bronco II 4x4 5 speed. It has a blown head Gasket which I was thinking about replacing, but pulling the heads is easier with the engine out, and if I going that far, I figure I might as well swap in a 4.0.
There is a guy selling a 98 Ranger with the 4.0. He took the transmission (Automatic) and is scrapping the rest. Says the engine ran good before he took the tranny. $350.00 Figure I may also be able to use the front axle so the price is right.
It seems most of the info here involves pre-1996 4.0's. I've skimmed most of the articles and haven't seen anything.So just wondering if there is any reason why a 98 wouldn't work.
Thanks in Advance!
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
Thanks in Advance!
'98 will work fine, provided you swap the necessary wiring and engine bay componennts along with the engine. '98 will be an OBDII 4.0 with PATS, which means more wiring changes. You will also want a 4.0 computer for a 5 speed.
If you were to swap the entire engine bay harnesses and dash, then you would have very little splicing to do; fuel pump, tail lights, etc. Putting a '98 Dash into an '89 isn't quite a bolt in swap, like a '94 and earlier would be.
If you were to find a '94 or earlier 4.0 wiring harness and computer it would make using the '98 engine a little less work.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,846
SW Iowa
Engine Type
V8
5.0
Front axle is worthless to you, the rear would be a little bit of an improvement if the gearing is right. It won't be a drop in deal in a BII IIRC, you will need to change the mounts some for a BII.
Efordman
The computer location is completely different and the factory harness will not reach to the broncos location without extending the harness or relocating the computer... I am putting a 99 ranger 4.0 with anti theift in my 86 bronco and trust me you are going to want every bit of harness from under the dash and under the hood
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
Just put a 96 4.0 in my 86 b2. Let me know if u want pics of wiring and all that good info. One of the Best swaps I’ve done.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
I have a 98 4.0 in storage. The transmission that came with it is already in my 94 super cab,
hopefully when I sell my other truck I'll be putting 98 4.0 engine in the 94.
I'll be tuned in if you do it!
Staff online
Members online
Shran
April Truck of The Month
