1994 turbocharger install
Rx7world
ford
I have installed a turbocharger on a 2.3 I am running everything else that came with the truck, just installed a turbocharger, all I wanted was 5psi of boost which I find is a nice little increase in power on other cars, and you don't have to worry about other things if you keep the boost low. The truck runs fine the only problem is the air control valve lets air through when you let up on the accelerator pedal ( causing engine Idle to go up), kind of annoying, I removed the air control valve problem solved but of course wont idle when cold, I think if I re-install the ACV and set the blow off valve at a lower pressure it might fix the problem, anybody run into this problem before?
shaggys2gen
Woodruff SC
2.9/6.0
Im not sure what the flange looks like on your IAC valve, but if possible flip it the opposite direction than what it is now, you boost either weakend the spring or the pressure is pushing it open, if you flip it backwards it will still function but cant be forced open by boost.
Rose2300
7
ID
Toyota
3.4
wrong section bro
Members online
Shran
April Truck of The Month
