dual high pressure fuel pumps?
Mike83
Abbotsford, BC, Canada
Hey everyone. It appears my low pressure pump seized cuz the wiring from the tank forward melted. I have a high pressure in tank pump from a 96 bronco laying around, and I was just wondering if I could throw that in and leave the one in the frame rail? Or are they gonna fight each other? I know I could just remove the one from the frame rail, but to be honest I'm feeling kinda lazy and pissed off with his thing. Any insight is greatly appreciated:)
bf750
12
Ky
Engine Type
V8
2. Crap
2WD / 4WD
It is what it is
high pressure pump in the tank should be fine
wildbill23c
TRS Banner 2012-2015
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
From experience of doing things 1/2 ass to save time and money...DON'T!!! either do it right or don't bother with it at all and take it to a shop. You end up spending more money in the long run trying to undo your 1/2 ass repair than you would by doing it right the first time. At the very least if the frame rail pump is in fact bad that should be removed, otherwise you may not get proper fuel flow if any fuel flow at all through the dead pump.
Mike83
My high pressure in the frame rail is fine. It's the low pressure in the tank that's seized. Just wondering if putting a high pressure in the tank without removing the high pressure in the rail will screw with anything. Having 2 functioning high pressure pumps.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
The pump in the frame rail may not be able to handle the higher incoming pressure so it may cause that pump to fail that would be the only thing I'd worry about.
Mike83
Yeah, that was my concern as well. Figured I'd ask:) thanks very much.
alwaysFlOoReD
Forum Staff Member
5,094
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
IMO I'd try leaving the frame rail pump. I'm lazy too. But I would carry a piece of high pressure hose and two hose clamps just in case.
Sent from my XT1032 using Tapatalk
Staff online
Shran
April Truck of The Month
