New to TRS. Advice on swap.
Cncproformance
2.3 to 5.0
Morning. Just purchased a 88 ranger as a project truck. Its a 5 speed, 2WD with a 2.3L. I've read the tech articles on the 5.0 swap which is pretty straight forward. My plan is to keep the original 5 speed and put a carbed 347 in place of the 2.3. I was wondering if any of you have some advice or lessons learned from swaps that would help me out. I don't want to start buying parts prior to the start of the build in reference to an issue that's written in the tech article and find out that for my application it wasn't needed. Area's which I plan on changing are: rear end 7.5 to either 8.8 or 9in, body lift if needed to clear the bellhousing if not needed I have a good size hammer, 2.3 to 5.0 of course...basically the items covered in the tech article. Is there anything else???
Mac
183
C. Wisconsin
2000
199
4.0
First step is to forget about the stock trans, covered pretty good in recent post. http://www.therangerstation.com/forums/showthread.php?t=150918
Usual manual replacement is a Mustang T-5. no lift required. Better find one of the better, stronger ones if you are planning on a 347. 8.8 is usually strong enough unless you go crazy with wide slicks.
Dave
Cncproformance
2.3 to 5.0
Thanks for the reply Dave. I'll go with the T-5. Will there be any massaging of the floor board needed for the shifter, forward or aft? I'm not planning on putting slicks on it just a nice 'street' tire.
Mac
183
C. Wisconsin
2000
199
4.0
Shifter location does move back 5-7". Some have dealt with that using a modified shifter lever or the expensive S-10 tails haft modification. TeddyZee (and others) shave some pictures showing the metal removed and new covering. Sometimes interference with bench seats, depending on their location.
Dave
Cncproformance
2.3 to 5.0
Sounds good. Is there anything else I should consider? I see there are only a few types of headers I could use. I was wondering if I could use Advance Adapters SlickFit Headers 717044A. They are not listed in the tech article however, Summit Racing states that they can be used for this type of swap.
Cncproformance
2.3 to 5.0
PERFECT! Thanks Dave! As you can see i'm still in the planning phase of this build. As time goes on i'm sure i'll have more questions or comments regarding the swap. Until then thank you for your time and quick responses. Have a good rest of your day and Happy Easter. :icon_thumby:
Cncproformance
2.3 to 5.0
Thanks Dangerranger83. Is there a reason why I should use an explorer rear end instead of another ranger or 8.8 sedan rear end. Just curious.
Cncproformance
2.3 to 5.0
Never mind, should have read the article before I asked the question...
dangerranger83
5.0 HO under the hood!!!
Solid Axle Swap
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Disk brakes, 31 spline axles. If you get a l/s one, it will more or less need the clutches replaced. If going with an open carrier, you have more options on if you want to lock the rear or not.
Sent from my SPH-L710 using Tapatalk
Cncproformance
2.3 to 5.0
Locking the rear really isn't necessary for the application. Just looking for a streetable cruiser type setup.
gsp
Ranger
I run Ford Racing track lock in 8.8,,, plenty, click my build thread
Cncproformance
2.3 to 5.0
Sweet build! That's basically what i'm doing minus the root style supercharger. Which crate motor did you get? You put some real money in that truck. I'll be referring to those pics for ideas. I see you used a standard style water pump and located the fan as a pusher, any fitment or cooling issues with that set up? The 8.8, funny, I just put the same diff cover with the cap reinforcements on my mustang. I have a rear end out of a police crown vic with 355's in that. I'll be looking for an 8.8 out of an explorer with 373's and i'll throw some goodies in it for the ranger. thanks for the reply and i'll post my progress as time goes on. Nice job on the build! I wouldn't change a thing! Cheers! :beer:
gsp
Ranger
Ford Racing 347, 8.8 from 94 Ranger 4.0 4X4, bolt in with no mods on a 1993, no issues with cooling,,, Griffin Radiator,, 93 Mustang Pulleys and parts
From and old thread:
1993 standard cab ranger: $1000
Tool Box: $100
Flat Bed: $150
Wheels tires: $650
Suspension rebuild: $500
8.8 build/trak loc/axles/gears: $650
fuel system: $250
Built WC T5: $1000
Centerforce Clutch Assembly: $450
Clutch pedal mod/quadrant/cable: $250
Crate motor: $7500
Headers: $350
Exhaust: $200
Accessory drives/pulleys/PS/Alt: $500
Radiator: $350
Relocated battery and -2GA cables: $325
hoses and oil filter kit: $100
Synthetic dope, oil and ATF: $130
Blower Holley/Air Filter/throttle stuff: $1200
Mallory dist: $400
head liner/carpet/seat covers: $400
gages: $450
Drive shaft/joints: $150
Paint: $30
Electric fan: $100
Grant Steering Wheel and adapter: $125
Mallory ignition noise suppressor: $50
Fire Extinguisher: $20
Blower and related parts $5000
Total ~$22,380
Members online
Shran
April Truck of The Month
