97 Exploder power steering pump
Terminator
BrokenArrow,Ok
which one
ford ,Jeep,Dodg
V8 all the way
what is a good upgrade power steering pump for a 97 Exployer with a 5.0?
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,800
Rapid City SD
Engine Type
V8
5.0
You might be able to do a Saginaw pump but the bracket and everything will have to be modified. There are other companies out there such as PSC and Howe that might be able to help you.
Terminator
BrokenArrow,Ok
which one
ford ,Jeep,Dodg
V8 all the way
yeah mine has the serpentine belt and with the AC dont know if I can get a upgraded power steering pump or not
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,800
Rapid City SD
Engine Type
V8
5.0
For what reason do you want a better pump?
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
The pump the 5.0L explorers and the 4.6L modular motors use are a higher output pump than the ranger's pump, It will run anything you add to the system, including ram assist and/or hydro boost...I'm doing both
SVT
Terminator
BrokenArrow,Ok
which one
ford ,Jeep,Dodg
V8 all the way
dana 60s front and rear and 39.5 Super Swampers
my power steering pump just went out ...and if their is a good upgrade that will bolt on to the factoy ...I want it :icon_thumby:
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Because of the way the pump is made and bolts to the bracket, there is not enough room to bolt a saginaw pump there. You can use any pump that was bolted to a modular motor (4.6L, 5.4L, etc) that has a remote reservior...If you do a search here there is a member doing a V8 swap that swapped to hydroboost from a 98 cobra, he has a pump but he can't use it, I'm sure he'd sell it for cheap. I could locate the thread for you if your interested:icon_thumby:
SVT
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,800
Rapid City SD
Engine Type
V8
5.0
Gotcha - are you doing hydro assist or full hydro then?
Terminator
BrokenArrow,Ok
which one
ford ,Jeep,Dodg
V8 all the way
I guess ill just put a stock one back on then
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I'm doing both hydro assist and hydro boost....
SVT
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,800
Rapid City SD
Engine Type
V8
5.0
SVT
What are you using for the hydro boost master cylinder? I have thought about running it in my rig too.
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I'm building 60's for my rig, so I went with 03 superduty hydroboost and master cylinder, since I'm running the same calipers from that year truck...There is another member on here that used a 98 cobra unit, and only had to redrill the two upper mounts, and extend the shaft to the brake pedal about a 1/2 inch...
SVT
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,800
Rapid City SD
Engine Type
V8
5.0
Hmm, cool. Thanks for the info!
Staff online
Shran
April Truck of The Month
