410 cam installed valvetrain ticking
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
Has anyone had an issue with this cam making their motor tick. I've tried literally everything to no avail wondering wth is going on. I even have 2.9 rockers and rods and have bottomed the lifters out to make them basically solid and it still ticks, getting very irritating! Wondering if I need to drop the dough on some sealed power lifters and go back to stop rockers, anyone have this experience ? I also have headers and am unsure if this is adding to my noise
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Exhaust leak and fuel injector "tick" will have the same timing as rocker "tick".
But rocker tick is mechanical, exhaust and injector is not, well injector is technically, lol.
So just to take it off the table, unplug 1 injector at a time and start engine, it will miss but if "tick" is gone then either that injector or exhaust on that cylinder is the issue.
Rocker tick will still be there whether cylinder fires or not
cp2295
7
Washougal, wa
Ok, i also ruled out any wires arcing by unplugging those one at a time and seeing if the noise would go away, and it didn't (guess I also ruled out a rod knock or a bad wrist pin...)
The only weird thing is when I'm driving its uneven and I can hear it when going down the freeway even. It's extremely frustrating lol. [emoji35][emoji379]
Another thing I don't believe it can be an exhaust leak because it doesn't get any louder with more load, like an exhaust leak would, not saying it isn't that though.
Another question will headers amplify my noise, and could it be possible I'm hearing the valves hitting the valve seats? Because I can hear it quite well with a stethoscope through the headers.
I have comp 988 dual valve springs too.
At this point I'm almost ready to say to hell with all of the mods and just put a stock cam and valve train in it, I'm building another car to go fast anyways, but boy do I love that sound at idle she makes.
cp2295
7
Washougal, wa
I just can't see how it's possible for the truck to be ticking, it's very loud. I bottomed out the lifters and backed them off until I could just turn the pushrods, so in my mind there's no way for there to be any slop. Another thing I want to mention is it is fairly quiet when cold and loud as hell when hot
cp2295
7
Washougal, wa
So I put in melling lifters and got rid of the headers and I have a huge exhaust leak since the flanges on the y pipe are bigger, just need to hit up the exhaust shop and get those fixed up but no more valvetrain noise. If there is any it's very small and totally tolerable but I think most of my noise is that exhaust leak. No more ticking when I'm cruising and let off the throttle, and no more on the freeway. Once I get the exhaust leak fixed I'll finally be able to drive the thing without my radio blasting, thank god I kept the stock manifolds!!
Headers are for sale btw [emoji23] $100 used for about 2000 miles, pacesetters. Made for 98-00 4.0 ohvz
RonD
Official TRS AI
8,370
canada
Well hopefully it is gone.
Doesn't make much since to me either, as loud as you described that tick there should have been some sign of it when adjusting the valve train.
cp2295
7
Washougal, wa
Yeah no kidding. That's why it took me so long to figure it out, but I swapped back the 4.0 rockers and pushrods also, and preload was good, I have the 5.550" pushrods. First start up was quite rattly but once the lifters pumped up no noise.
It's quite weird that couldn't find and wearing on anything, it all looked smooth. I'm wondering if with the headers it was transmitting noise from the valves hitting the seats but idk.
cp2295
7
Washougal, wa
Well it's back with a vengeance within 2 weeks..... I hate this truck lol, this seems unorthodox but I'm curious if I'm running too thick of oil? I have 10-40 right now in it, it's louder when it's cold and even though it's still prominent when it's hot it is quieter, makes me think possibly my oil is too thick? Any thoughts?
Staff online
Shran
April Truck of The Month
