jacepaul79
- Sep 26, 2016
- Reaction score
- 0
- Make / Model
- ford
- Manual
so I've been searching the forums and have bits and pieces of info... trying to get a shopping list going... I have a 302 block from a 78 Lincoln and a 5 speed from a 97 f150. my project is an 86 with a fi 2.3 and 5 speed, manual steering manual brakes. Being a 78 block I was told the balance is different from the new motors and I wouldn't be able to get a flywheel for the newer trans. No biggie I'm doing a rebuild anyway, but I assume that means I need a new crank too? I like the idea of the 347 stroker but that puts machining way up there so checking my options there. as far as the trans I see options of a M5OD 1 and 2 whats the difference? for those maintaining the hydro clutch what are your suggestions for the master and slave units? what clutch are you using? as far as rear end im looking for an 8.8 expo unit but did I read a ranger fx4 is a direct bolt in? I'm keeping it carbed to be a simple swap and I plan on getting parts together this season then tear into it next winter. Oh... planning on the fox body vert mounts and the tri y headers. I'm sure theres lots of posts about pros and cons to these, have you guys had luck? Thanks for the help!!
