1977.5 F-250 alternate steering box
jtaborsky
7
Bismarck ND
4.0L OHV
4"
32's
Break. Upgrade. Repeat.
I picked up a '77 3/4 ton. It runs fine, but the steering is so awful that I can't drive it on the street. I get about 1/3 of a turn on the steering wheel that is nothing but play. My thoughts are replace the gearbox, but they are $300+ for a reman. Is there an alternate part I could use or some kind of a conversion I could perform to make a different part work?
Thanks.
- Joe
BLOODBANE
19
Canon City, CO
FORDFORD
347, 4.oh
Is this the power assist set up (the one with the arm on the axle to the tie rod)? If it is, its a pretty touchy system. I had a 73 with that set up. Last I knew you had to send your unit in and they would repair it and send it back (sector/box/ram). You might make sure all the seals are good as well as the sector (arm from the box on the outside of the frame that the hoses go to/from).
I never found a bolt in replacement for this. I had rumors of possible a early dodge box, but that was always a maybe and no one could give me a definite answer. With fabrication, anything is possible though.
Mickey Bitsko
Pagosa Springs CO>
live everyday like your gonna die tomorrow
Power assist was 76' and earlier I believe, probably best bet is the old wrecking yard.
Mickey Bitsko
Pagosa Springs CO>
Thanks.
- Joe
Looked it up , you are correct, LMC wants 299.00 for a box...wow !
alwaysFlOoReD
5,135
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I have a 2wd 1977 f250. I found the rag joint was the major problem with mine. I also tightened up a little slack on the adjustment on the top of the box but am leery because I've over tightened them before....ruining the box.
