bluebombersfan
- Nov 4, 2008
- Reaction score
- 0
- Make / Model
- Ford
- Engine Size
- 3.0
I checked the online manual and it says 2340 lbs? Seems a little low. I want to know if I will be able to tow a 22' sailboat with a displacement weight of 2200 lbs plus trailer. I would only tow it twice a year to the lake about 100 kms each direction, in the prairies, so flat land. But I think it's illegall to tow anything beyond the manufactured specs from what I have researched so I want to make sure my truck will be in compliance with towing it. If 2340 lbs is correct max tow weight then I would be over aprox, 600 lbs is my guess.
I have a 2006 Sport 3.0L 5 spd supercab, gear ratio is 4.11, but in the 2006 manual it says tow rating is same regardless of gear ratio's which I found odd.
