8.8 rear end on 84 bronco ii
7111127
Coweta Oklahoma
4.0
i gonna be puttin a 8.8 on my bronco ii has anybody done this b4 and got any tips?
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Check the tech library, I'm pretty sure several people have done it.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Match gears, bolt in, make sure your wheels don't stick out too far, install flares if needed, have fun?
7111127
Coweta Oklahoma
4.0
well i gotta weld spring perchs on and shock mounts lol i worryed i might put em 2 far apart or off set
dirtcowboy
Solid Axle Swap
5
NW Montana
FORD
2.9, 4.6, 4.0, 6.8, 5.0x4
The perches and mounts go in the same spots as on the 7.5. measure twice, weld a bunch.
spdcrazy
2
Homer, alaska
mostly 86
B2
2.9 bored and cammed
you just need to think of everything step by step. double check your measurements.
i'd do it this way, get your perch's on the axle (NOT WELDED) then put it under your truck. a little tap tap this way, and a tap tap that way to cent it. then set your pinion angle, tack weld the perch's in place. then remove and weld the rest. then go from there!
pwrranger88
2
rhode island
4.0,2.3
you'll need to do something with the driveshaft cause the one on your b2 bolt up to the 8.8
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
all you gotta do is change the flange at the ujoint, if you are using the real driveshaft.. if using the cv axle thing, then change it anyways... lol
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
ah. You didn't say EXPLORER 8.8. :icon_rofl:
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
That shaft might be a tad long.
Members online
Mudtruggy
May Truck of The Month
