1993 5.0 in my 1992 ranger?
cumminsranger52
When swapping a 1993 302 from a bronco into a ranger will it be basically a plug and play?what all will I need to do, I have the suspension I need and I have transmission and a transfercase pretty much everything is from a 1993 ford bronco
dangerranger83
5.0 HO under the hood!!!
Solid Axle Swap
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
cumminsranger52
Aftermarket hood I guess would fix that
dangerranger83
Solid Axle Swap
54
Lafayette, IN
Either get a mustang, mark vii or explorer intake setup and you should be good
Sent from my SPH-L710 using Tapatalk
cumminsranger52
Are you talking about the whole setup as far as air intake, intake manifold etc. or what?
dangerranger83
Solid Axle Swap
54
Lafayette, IN
Intake setup.
Can't remember if those engines are HO or not. If not, then grand marque or crown vic is what you will need.
If going carb then clearance shouldn't be an issue unless you mount the engine up crazy high with a large air filter housing, high rise intake and stupid crazy thick carb spacer combo.
gsp
Ranger
Or roots blower...
cumminsranger52
I forgot to also say I have a 3" body lift so will I clear?
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
The truck intake will not clear, not with a 3" body lift, doubtfull with a cowl hood and body lift. Go with explorer intake. Flows about the same as a mustang GT40 intake...
SVT
cumminsranger52
Ok will do, is that gonna be my only problem?
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
The tcase (1356) is a little wide but can be made to fit. Besides the electrical wiring, which I would grab the EVTM from both trucks, the heater box mod, and your choice of motor mounts, the rest is easy...
SVT
Staff online
Members online
Shran
April Truck of The Month
