Timing and tuning suggestions for a duraspark /offyhauser 2.8
MrE_Powers
12
st. chuck county, mo.
ford
3.0,4.6,2.8
My duraspark/offyhauser 2.8 is leading me to be leave it is running lean. My father an d I want to check timing and set the carb flow but cannot locate 2.8 pinto settings. Any one got links or info for me to tune this thing please
Sent from my SM-G530T1 using Tapatalk
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
It's been a while for me, probably fifteen years since I messed with a 2.8. Once you've durasparked, don't you just disconnect the vacuum advance hose and set it to 10-12 BTDC at warm idle?
kimcrwbr1
46
maplevalley WA
ford
2.8l
Do you have a ported vacuum on the carb? I just put a 8.5hg power valve in my carb and it made a big difference. Preset the idle air needles 3 1/2 turns out from lightly seated the 2.8 runs alot better on the rich side at idle speed it also supplements the intermediate circuit. With the vacuum advance disconnected set the base timing at 10 dbtdc. Then you can dial in the carb. Turn the needle in slowly until rpm just begins to drop and then back out 1 full turn.
kimcrwbr1
46
maplevalley WA
ford
2.8l
Search 125-85 power valve on ebay
Members online
Shran
April Truck of The Month
