Dana 35 build
4.0B2
151
Walls, MS
4.0 v6
I wanna do only suspension for 33's. Maybe a one inch body...
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
Cut the shaft yokes for full circle snap rings and use 5-760X spicer u joints. 5 years of wheeling on that setup for me and 0 failures.
Tb8983
Forest Grove, OR
Not big enough
So reading this post my 4inch lift when I put the d35 in I'm gonna have to get different drop brackets or will the ones that come with the kit work
spdcrazy
Homer, alaska
mostly 86
B2
2.9 bored and cammed
drop brackets for the d28 and d35 are interchangeable.
4.0B2
151
Walls, MS
4.0 v6
You just need true drop brackets the rough country lift uses a drop plate on side to lower the factory bracket. This can cause damage to the larger d35 member under flex. It creates a space issue.. You need like skyjacker brackets
