No Spark
JMilton
Firefighter
EMT / Paramedic
Long Island , New York
2.9 v6
Okay guys here's one I just cant figure out.
1988 Bronco II 2.9 Automatic
Here's the deal ,
No matter what the temperature out , 90 degrees or 15 degrees my truck will start on the first crank without any hesitation. She will run beautifully all day without even a hiccup. However without fail , the second you shut her off she will not start again until she's cooled down all the way.
The truck is not putting out spark to the distributor cap.
:icon_confused:
I haven't the slightest idea what could possibly be causing this.
Any ideas?
My first guess would be the TFI is dying when it gets hot.
Try this before doing anything else. Get it good and hot to where it won't start normally, then get out your screwdriver. Put the key in run and jump the relay terminals. If it fires over you have a wiring problem and I'll explain more then.
If it still won't start, get a new TFI.
