1983 sbf/c4/8.8
tsi617
Well here it is, picked it up a few months ago and havent done much to it, put about 40 miles total on it. Needs a good amount of work, mostly due to neglect in upkeep, brakes, fluids, ect, some corrosion love, a full rewire, some plumbing and repair a leaking c4 tail housing.
as they say...pics or it never happened...
tsi617
the motor...
the rear end...
it had a casting in it of RF-F07W-AA
that lead me to decoding it to a 8.8 from a 1990 ford ranger. it doesnt have a id tag as the previous owner tossed it so i will need to count the pinion rotations to wheel rotations when i get the truck jacked up to do the brakes.
and the start of the frame restoration, i am hitting the frame down with my grinder and a wire wheel and then hitting it with some of the krylon rust primer. i plan to strip the primer in a few weeks when i order the rust bullet paint so i can lay that down, then top coat it with some black spray paint just so i dont have a steel gray frame.
tsi617
finished the frame up. ordered a new gas tank and shocks. need to order the fuel lines and some other things for the back before i drop the bed back on.
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
nice job on the tank:icon_thumby:
dangerranger83
5.0 HO under the hood!!!
Solid Axle Swap
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
The engine looks like a factory install, very organized.
Sent from my rooted SPH-D710 using Tapatalk 2
tsi617
Thanks all
Sent from my SCH-I535 using Tapatalk
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
i had planned to make a vee tank(dual saddles) so i could get 40 plus gallons under my stock bed.... i made it out of cardboard at one point. it was too tight
for comfort and required the exhaust to be run outside the rail, but i had plans for a flat bed and figured its deck height into using a more conventional tank. i was worried about damaging that much custom work offroad and pussed out and went with a plastic tank from a b series van and settled for 34 gallons. the b tank is cool because i can add to its capacity easy enough from its bottom load filler setup...but thats also a potential weak point as well obviously.
your feed setup was in my plans but tighter. looking at how yours turned out i think setting up two oem tanks with a medium sized box connector could easily accomplish what i attempted initially. i am just leery of welding up old tanks.
got my tiny little brain rethinking stuff now.:D
except i want 50 gallons.....its a tough order for oem framerails.
tsi617
Yeah the new tank was about 130 from lmc truck
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
a plastic tank in the end was an easy choice...just not sure if it was the right one....
here i was trying to figure out how to get it in there....found these today
i ended up compromising a bit but made a place for it. it cut into my planned battery storage. buying, modifying, and connecting two new tanks is still pretty cheap....when i called around for a custom tank to my specs it was over 1300 bux in alum and 1800 in stainless...mild was almost a 1000....so no way i was having it done. when the time comes to revisit this i will consider it. the plastic repair kits are not as good as the metel ones.
tsi617
Mine was done solely for performance. I didn't want to install a fuel cell as it may be a failure in some states for the annual safety inspection.
tsi617
So pulled my starter to find 24 e7te ca 7h12.
Therefore my block is a 87 out of a truck casted on July 12, 1987.
It is topped off with a set of world heads, edlebrock intake, a holley carb and a mallory ignition.
No idea of the can is roller or flat, just going off castings and what I can see. This truck and block has been hot rodded a little to much.
Sent from my XT1080 using Tapatalk
dangerranger83
Solid Axle Swap
54
Lafayette, IN
85 was the beginning year of the roller block so you more or less have a roller block.
Sent from my SPH-L710 using Tapatalk
tsi617
Te blocks used roller and tappets randomly until 91 when they went all roller.
dangerranger83
Solid Axle Swap
54
Lafayette, IN
I'm happy I got a roller block and it's also a 91. Converted it HO with a cam swap out of an 85 mustang.
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
