Thunderbird motor
jeepfreek
lanesville Indiana
Got the truck running today !!!! It was a ground wire issue , one that I must have missed. Thanks for all the help. I'm sure I will have more questions before its done.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
nice. if you confirmed valve events were correct and not popping still, i would have offered to send you a harness to test with and then copy from.
were you having loop issues from the tfi shielding or was it a case ground issue?
jeepfreek
lanesville Indiana
It was a gray wire with a red strip, comes out on the harness in 4 spots. My etvm says its a ground for ride control, fuel sending unit, vss, and shock tower.
I still think my harness is jacked up. But its running. Not very well but it does start.
Elutheros
129
Central Texas
Glad you got it running. I know how frustrating those kinds of problems can be.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
well all of my stuff is packed.....so your screwed now.:icon_twisted:
jeepfreek
lanesville Indiana
Truck seems to be running better, finally got the moates quarterhorse loaded and starting to do some work with it. Still haven't driven the truck on the road need to finish the exhaust and put the body back together.
