86 b2 no power
xracer18
alright guys, I have question to see what your thoughts are about my B2.
Its and 86 v6 2.9. recently i have done both fuel pumps, fuel, and air filter, complete tune-up along with new distributor, cap and rotor, I also have a new O2 sensor in it as well. Along with lots of seafoam. It still feels sluggish. I never really cared much until i drove my friends 89 (all stock) b2 v6 2.9. it had so much more power than mine. i just am confused one what to do next to get some more power out of it. Im probably going to cut my cat converter out and see if that helps. (i dont have emissions where im from). has anyone seen and or felt power difference by clearing the cats out of them. Another thought i had was to replace the map sensor and any other intake sensor it has, but im not sure if that would do any good. any other thoughts on what direction i could do next?
8,370
Working Cat converters or working EGR system can't hurt performance, a myth
Low power comes from Low Vacuum which means low air flow
All engines are air pumps, self powered air pumps, but still just air pumps
The more air you can pump the more power the engine has
Bigger engines have more power because...................................they can pump more air
Turbo or super charged engines have more power because................wait for it...........they can pump more air
So pretty simple stuff when you get right down to it, more air = more power, less air = less power, rocket science it ain't :)
Now a clogged exhaust would mean you can't pump as much air, so less power
Low compression would mean you can't pump as much air so lower power
Throttle plate not opening all the way would mean you can't pump as much air so less power
Air filter or inlet clogged would mean you can't pump as much air so less power
Check that when gas pedal is down to the floor, the throttle plate is open all the way
Google: Ranger throttle cable mod
Very common issue with Rangers/BII, stretched throttle cable
A Vacuum gauge runs about $20, best tool since the invention of gasoline engines
Doesn't matter what "do-dads" they add to the outside of an engine, it always was and always will be just an air pump
And you test an air pump with a pressure gauge, jeeze who would have figured that out, lol, yes pretty much every one
Good read here on some tests and what they mean: http://www.gregsengine.com/using-a-vacuum-gauge.html
very easy to do these
Check the "clogged exhaust test" at the bottom to see if Cat or muffler is clogged
Compression test can take the compression issue off the table, or tell you not to waste money on non-fixes
Compression can't come and go like spark or fuel issues, you either got it or you don't
All spark plugs removed <<< a must
Test one cylinder at a time and WRITE DOWN results
I would expect 2.9l to be at least 150psi in each
xracer18
Thanks. I'll look into that. I actually first got it going and it could barely get going out of its own way. I found out the timing was way off. So I fixed that and it helped a ton but still feeling slow. I'll look into that stuff.
8,370
1986 BII used TFI spark system with an assist from the fuel injection computer
TFI module sets base spark timing on its own, computer "suggests" spark advance/retard info based on driver input, i.e. throttle position
There is a SPOUT(spark out) jumper that you needed to remove to set base spark timing, 10-12deg BTDC, and then put SPOUT jumper back in place so computer could assist TFI again.
SPOUT is the wire that has the computers "suggestions" so power would be low without SPOUT connected
xracer18
Thank you, where is the spout located?
8,370
Depends on the year but most 2.9l had the SPOUT jumper near distributor passenger side between valve cover and fuel rail, but it can be on drivers side as well.
Picture here: http://s527.photobucket.com/user/gertsdsbs/media/spout002.jpg.html
And here: http://s25.photobucket.com/user/CRaSAfe/media/moto_0033.jpg.html
You pull out the plastic "jumper", then start engine, set base spark timing, some like 10deg BTDC, other like 12deg BTDC, Ford spec'ed 12deg
After timing is set turn engine off and reinstall SPOUT jumper
xracer18
thank you for your help
xracer18
It worked! Much more power now. Thank you so much
8,370
